Tuner Locking Removal.
Old 08-18-2012, 06:18 PM
99VetteFRC's Avatar
Default Tuner Locking Removal.
I have a blue/green PCM out of 03 Silverado in my Chevelle. I read the tune and removed Vats and when I saved it, HPT converted to a 1Bar enhanced and tuner locked the tune without me telling it to. I also read and liscensed the PCM from a friend's 99 Camaro and it has tuner locked that tune too.
What I need to know is there any way to convert my truck tune back to a standard tune and to keep the HPT from tuner locking all my tunes.
Old 08-18-2012, 06:46 PM
salemetro's Avatar
EMAIL Bill at HpTuners....he should be able to steer you in the right direction, if not solve the problem for you.
Old 08-18-2012, 06:53 PM
99VetteFRC's Avatar
I was just cruising the HPT forum and found NADA!!
Old 08-18-2012, 06:54 PM
99VetteFRC's Avatar
I also figured out that it is not tuner locked, its OSmod locked.
Old 08-18-2012, 09:36 PM
MontecarloDrag's Avatar
If you can read the tune from the PCM then it's not locked in any way.
You either don't have the license to modify it, or it may be a custom OS from another company
To avoid locking all your tunes, open any file, click EDIT - CALIBRATION DETAILS.
There is a lock with blue frame (left to the help button). You need to disable it, thats it.
Old 08-19-2012, 10:35 AM
99VetteFRC's Avatar
Yeah I saw that, but it seems to OSmod lock any time I save a tune after a change.
Old 08-19-2012, 10:45 AM
2xLS1's Avatar
If you are not applying a COS to the file yourself under the OS tab then the files you are reading out of the vehicles have already had a COS applied to them by someone else using HP Tuners. That's it. That is the only way a COS mod lock can happen.
Old 08-19-2012, 10:50 AM
99VetteFRC's Avatar
Than I must be doing it somehow not knowing how I did it.
Old 08-20-2012, 02:49 PM
dodson55's Avatar
even if it is tuner locked by you you can still use your hp tuner on it idk how you could have did a 1 bar enhancement without knowing because you have to do a write entire and to use the extra credit it pops up with a warning lable asking if it is what you want to do
Old 08-20-2012, 06:40 PM
BLK02WS6's Avatar
It was not tuner locked, it was OSmod locked because of the application of the COS. I believe that after the COS was applied, that tune was saved over the original file and therefore, every iteration of the tune after that was OSmod locked.
Old 08-20-2012, 08:16 PM
99VetteFRC's Avatar
No one seems to want to share their stock OS with me.
Old 08-20-2012, 09:04 PM
2xLS1's Avatar
I don't see where you asked anyone to.
Old 08-21-2012, 04:35 AM
99VetteFRC's Avatar
I posted onther thread. I did find it in the HPT repository.
Quick Reply: Tuner Locking Removal.
