cylinder honing
Old 08-21-2012, 09:11 PM
ls1m6nichols's Avatar
Default cylinder honing
I recently honed my 98 ls1 block. I read that the preferred grit stones more polymar piston rings is 280 grit and finer. I used one 400grit, the cylinder walls look good, but the scratches are small. Anyone have some advice?
Thanks
Old 08-21-2012, 09:12 PM
wildcamaro's Avatar
400 grit is why I have used on ls engines and what tony mamo suggested to me...
Old 08-21-2012, 09:48 PM
bww3588's Avatar
The key to a good home hone is getting the crosshatch angles right and a proper plateau on the walls.
Control on the drill and consistent stroke speed will net that. Just start with a rougher grit and finish with a finer grit to achieve a decent plateau.
Old 08-22-2012, 08:12 AM
Do u think I should hone it with a 220grit a little and smooth it out with the 400grit? Even after I've already used the 400
Quick Reply: cylinder honing
