12.79:1 compression on pump gas??
Old 08-22-2012, 01:55 PM
lt1_2buku's Avatar
Default 12.79:1 compression on pump gas??
Anyone running 12.7ish:1 at the pumps?
Old 08-22-2012, 01:57 PM
RamAir95TA's Avatar
I am.
Old 08-22-2012, 02:00 PM
MEAN LT1's Avatar
It can be done. What's your DCR?
Old 08-22-2012, 02:38 PM
fex77k's Avatar
Yea, it didn't much care for the summer. It loved 104 from the pump but 97 worked.
Old 08-22-2012, 02:47 PM
TwoFast4Lv's Avatar
Yup! Just choose the right cam
Old 08-22-2012, 05:56 PM
lt1_2buku's Avatar
It's an LE 242/248 110lsa 580ish lift. It's the cam LE Spec'd for my 383 build. Man I thought that just seemed high for street oh well. Will a stock starter eventually go out starting something with 12.5+?
Old 08-22-2012, 06:27 PM
bowtiedad_z28's Avatar
I am at 12.8 as well. Runs fine on pump gas. Its not the car in my sig.
Old 08-22-2012, 06:47 PM
lt1_2buku's Avatar
Man I want that hood^^^^
Old 08-23-2012, 07:26 AM
96capricemgr's Avatar
Tuner needs to know what he is doing.
Stock starter is a nice gear reduction piece, just give it a larger feed cable and it will be fine.
I know it doesn't "look" like a gear reduction starter but it is.
Old 08-23-2012, 08:02 AM
quik95lt1's Avatar
your sure as hell pushing it but get a GOOD tuner that knows his **** and you'll prob be ok long as you dont have a cam with like 0 overlap lol
Old 08-23-2012, 08:28 AM
stumprrp's Avatar
With a fairly mild 236/244 112 cam my old 396 ran great with 12.25:1 so i think youll be good.
Old 08-23-2012, 10:43 AM
lt1_2buku's Avatar
Well I Got a mail tune from Ion. I got the tune hoping it with get me to the nearest LT1 turner (about 2hrs away). Think it will be ok with that tune driving for 120 miles? Or should I just rent a trailer? Good to know about the starter thanks 96caprice.
Old 08-23-2012, 04:51 PM
I do agree a good tuner needs to be used as well.
And no you cant have my hood!! Lol
Old 08-23-2012, 09:33 PM
Rob94hawk's Avatar
Can you just mill the heads or do you have to design a cam around the designated CR?
Old 08-24-2012, 08:15 AM
lt1_2buku's Avatar
If I milled the heads I thought it would increase the compression? Is this backwards? I guess I could just go with a thicker gasket if I needed to lower it.
Old 08-24-2012, 04:46 PM
kgkern01's Avatar
Just curious, what heads are you running for this build?
Old 08-24-2012, 05:27 PM
lt1_2buku's Avatar
Running an LE2 set of stock casting heads 54cc. LE did say this cam loves high compression. I just wanted to know if I need to only run high octane or if 93 would be ok.
Quick Reply: 12.79:1 compression on pump gas??
