Dual tune PCM..........questions......
Old 08-23-2012, 10:11 PM
LS6427's Avatar
Default Dual tune PCM..........questions......
I tried contacting Frost....PM box is full.
If anyone knows......can this be done?
I'm building a forged 370ci. I want to spray it for about 6-8 months, then I'll be installing a single turbo kit.
Either in spray form or in turbo form:
If I use dual tune PCM......can I have my regular tune for running normally.......then throw a (hidden) switch to tune #2 that will activate the other tune for valet.......and that valet tune can be made so the engine cannot rev past 2,000 rpm.??????
Basically so these valet jackasses don't joy ride or romp on my car.
Also....do you know if Frost uses the 0411 PCM's for this?
Thanks.....
Old 08-24-2012, 05:17 AM
BLK02WS6's Avatar
You can do that with an EFILive custom operating system - with either N2O or turbo (2/3 Bar) - and it can be done on the 0411 PCM...
Old 08-25-2012, 11:36 AM
bmax's Avatar
This. I have a valet switch set up as a kill switch right now, but can change the parameters to whatever I want.
Old 08-25-2012, 11:18 PM
LS6427's Avatar
Can any tuner do this that uses EFILive?
So you're saying I DO NOT need the dual flash PCM by Frost....just any 0411 PCM?
Old 08-26-2012, 10:22 AM
CalEditor@PCMCalibrators's Avatar
We are working on a new Dual-Flash board to fix an issue. We don't have this project done. I am not sure if Frost can get any of the old boards that are left from the last batch. We have been working with Frost's supplier for over 4 years now.
We also list Dual-Flash untis, but I have a customer that wants several and we can not fill that order as of today
http://www.pcmcalibrators.net/
Old 08-26-2012, 12:44 PM
BLK02WS6's Avatar
Yes, any tuner can do it with EFILive.
From what you stated above, I don't see why you would need a dual flash PCM...
Old 08-26-2012, 07:55 PM
MUSTANGBRKR02's Avatar
Park your own damn car. Problem solved.
Old 08-26-2012, 11:09 PM
SMOKINV8's Avatar
This is confusing. Long story short, when will you likely have these and how much? I've got a number of FI cars in the area (and two swap cars in the works) that have all shown interest in these for E85/pump gas tunes, but it seems like they're rare to find in stock. I need someplace to refer them.
Old 08-27-2012, 06:05 AM
We have a fix for the old boards, but we are waiting on the new boards to come out. I will check in and find out if we can get either boards
Quick Reply: Dual tune PCM..........questions......
