91 240sx lm7 jack of all trades........no lm7, going ls1 now
Old 08-25-2012, 03:01 AM
turbonola's Avatar
Default 91 240sx lm7 jack of all trades........no lm7, going ls1 now
hello everyone, i'm just here to add to the growing number over import guys that wanna join the V8 train. my build will consist of the motor itself and it will be done on a budget. it will be daily driven, drifted, tracked (road race and 1/4 mile) and street raced. my goal to start out is the same amount of power i made in my built turbo 4 (370ish whp and 400+wtq). it will be sprayed if i get close enough to the 10's but all i need to do is beat my personal best time of 11.65@118mph 1.6 60' for this to be considered a success.
this is the car it will be going into
heres my lm7 (yeah i know its dirty)
picked up some goodies for it already
even found time to clean and paint the valve covers and front cover
also picked up a free lt1 t56 with a bad 3rd gear. need to get it cleaned put back together as an ls1 t56 (already researching whats needed).
enjoy, comment, help
Old 08-25-2012, 03:17 AM
LS1TA_956's Avatar
nice keep us updated.....i would also like to do a ls1 s14
Old 08-25-2012, 03:29 AM
turbonola's Avatar
oh also got a deal on ls6 valve springs
Old 08-25-2012, 03:47 AM
turbonola's Avatar
btw if anyone has alternator and power steering pump brackets i need'em
Old 08-25-2012, 05:43 AM
Tweek's Avatar
Welcome to the dark side!! By far one of my favorite 240s from the area, functional car that put in work in the east. Sure when it hits the road you wont be disapointed.
Old 08-25-2012, 09:54 PM
twoeyes12's Avatar
So which pistons/rods (compretion ratio)? will you be using?
Old 08-26-2012, 02:55 AM
turbonola's Avatar
Stock pistons and rods. Thanks tweek, I might make an appearance or two in mexcio since nobody wants to buy my radials. This build is gonna take time though. I'm really in no rush either. If you know of anyone with stock brackets hit me up on Fb or callouts.
Tore the motor down so I can do rod and cam bearings. Dunno about mains but I probably will.
Old 08-29-2012, 01:32 AM
turbonola's Avatar
ugh damn issac, not much umph but alot of noise
Old 09-09-2012, 04:21 PM
turbonola's Avatar
small update no new pics yet. got the motor torn down and i am planning on just doing new cam and rod bearings. thinking i should do mains also but dont want to tear the motor all the way down. project is gonna take longer than i thought because my roommate moved out so not much money to put into this right now.
Old 09-20-2012, 06:20 AM
turbonola's Avatar
Just picked up a wiring harness that's been modified and la else. Pics soon. Oh and I also picked up some arp head bolts.
Old 09-20-2012, 04:41 PM
turbonola's Avatar
also jegs dropped off some goodies for me today
Old 09-28-2012, 05:34 AM
turbonola's Avatar
picked up a throttle body for cheap. got a tps for it and the iac is on the way.
Old 09-28-2012, 08:32 AM
Nissan LS240's Avatar
looks like you're building your own headers, building your own mounts too?
Old 09-28-2012, 10:38 AM
Tainted's Avatar
you should consider epoxying the holes, and porting the TB along with the coolant bypass.
Old 09-28-2012, 11:20 AM
N2OBaby's Avatar
Great start there I sure it will be alot of fun when its all together.
Old 09-28-2012, 11:44 AM
jlee29's Avatar
Welcome to the club! You will not regret going v8 in your 240. I get a ton of attention from a huge variety of car enthusiasts. Its so much fun to drive also.
You may wish you went turbo if your building your own headers anyway. Its not much more to just make them forward facing with an ebay turbo... it may actually be easier not dealing with the steering shaft, lol. Hp is like sex, you can never get enough... I started with wanting a cam only car, and now im building a 80mm turbo setup... Anyway, keep up the work! There is a ton of good info out there to help you do it right the first time.
Old 09-29-2012, 08:32 AM
turbonola's Avatar
yeah i figured i could save a few dollars by build my own stuff. i will however be going with the hooker mounts
i might send it off to get ported, i dont trust myself porting stuff
i'll do the turbo thing in about 2-3 years, right now i'm amassing nitrous parts out the ***. i have 2 bottles why not.
Old 10-05-2012, 07:28 PM
turbonola's Avatar
updates
hsw bottle warmer
hsw purge
hsw nitrous plate
Old 10-06-2012, 04:56 AM
turbonola's Avatar
apr head bolts
Old 10-09-2012, 02:16 PM
good thing you have a s13, on the s14 that nitrous plate would make it impossible to fit an intake on, I wanted a plate but ended up using a direct injection kit
Quick Reply: 91 240sx lm7 jack of all trades........no lm7, going ls1 now
