15 inch drag tire. pics
Old 08-27-2012, 08:52 AM
baltsk8er69's Avatar
Default 15 inch drag tire. pics
15x8 with a 26 inch tire fits well. http://i1171.photobucket.com/albums/r554/baltsk8er69/IMAG2261.jpg
Old 08-27-2012, 12:01 PM
DavidGXP's Avatar
Fail. Please post another pic
Old 08-27-2012, 12:17 PM
jrob56's Avatar
OP I took care of it for now, but you need to wrap that link in these tags [img]insert link here[/img]
Old 08-27-2012, 12:42 PM
Awesome I never new that. Thanks for the info. It's off the ground because the lugs weren't deep enough....they only grabbed like 2 threads. But it fit no problem. They're the rears of a foxbody.
Old 08-27-2012, 06:04 PM
DavidGXP's Avatar
I didn't know a 15" wheel would fit a 11.928" rotor. Thats really cool!
For all of you gxp peeps, we can down size to the 2 piece f body rotors from baer beaks. P/n 2301006. Then use the monte/impala ss calipers and brackets. If you are worried about stopping power, then use the matching bare 4 piston calipers.
Keep in mind though that the 04-08 gtp uses 11.69" rotors with single piston calipers. The 2 piece rotors weigh 13.8 lbs each vs 24 lbs stock 12.7" gxp rotors.
Thats dam near 20lb weight rotational saving. With the 12" rotors I recommended using 93-97 rx7 wheels with a 26x10.50x16 mt et drags.
The wheels are super light 13-16lbs and are 16x8" with a 50mm offset. The bolt pattern is 5x114.3 but they will work for strip use.
The stock wheels are over 24lbs.
Old 08-29-2012, 06:37 PM
99slpws6's Avatar
Running spare tires on the back.
Old 08-29-2012, 10:35 PM
DavidGXP's Avatar
Thats a lot of *** end squat!
Old 09-02-2012, 11:44 PM
ImpSS07's Avatar
What rims are those OP?
Old 09-03-2012, 06:15 AM
They're weld draglites 15x7 with a 275 mickey Thomson tire. They're are a total of 26 inches tall. Which if you have 18s on stock tire...is the same height.
Quick Reply: 15 inch drag tire. pics
