Sponsored by: DashLynx
TA Fixed Headlight Retrofit
Old 08-27-2012, 12:54 PM
Striker289's Avatar
Default TA Fixed Headlight Retrofit
So My one Motors Burned up and ive had some down time so ive been messing with a retrofit. I had Bi-Xenon Projectors laying Around So it really hasnt cost me anything. I made Frames out of 1" Aluminum flat Stock. Still want to make bezels and maybe lenses to go from the lids to the body line on the bumper. No clue if i will accually Rock this set up yet. But i figured id share and get some input.
Old 08-27-2012, 01:24 PM
Copy & Paste Moderator
VIP1's Avatar
That looks awesome. Any more info/pics on the projectors and how you mounted them?
I can't tell from the pics, but are they completely sealed? Is there a lens in front?
This reminds me of an angry Johnny 5.
Old 08-27-2012, 01:43 PM
Striker289's Avatar
I can't remember the Model of the Projectors, Ill have to look it up. I had them in the Civic I used to DD, And one Bulb is goofy so ill have to order new bulbs. I heated up some 3" PVC and slid them in then sealed them. I still Need to make some kind of lense to Project the Bowls. They are mounted on aluminum Strips with hose Clamps. Which worked out good because it gives me rotational and Side to side Adjustment pretty good. Ill have too take pictures with the Covers off.
Old 08-27-2012, 02:15 PM
Z28RS's Avatar
That's a pretty cool concept you have there, OP. I wonder how your cool idea would affect the aerodynamics of your car?
Keep up your outstanding and resourceful thinking and post up some images of your completed design!
Old 08-27-2012, 04:23 PM
stevesfbody's Avatar
I hope you're planing on making some sort of bezel for it?
Old 08-27-2012, 04:45 PM
Blackbirdws6's Avatar
Very cool. Always thought the sleepy eye look would work well on these cars. Get a shroud to cover the big open area and this would be a nice setup.
Old 08-27-2012, 07:26 PM
Striker289's Avatar
shroud/bezel is planned for sure.
Old 08-27-2012, 08:28 PM
nice. its good to see different among the T/A guys. really anticipating the final result!
Old 08-27-2012, 09:38 PM
RAMPANT's Avatar
That is so funny, it is exactly what I thought.
Old 08-28-2012, 03:29 PM
00transamws6's Avatar
That is a unique way making projectors work. Any output pics?
Old 08-28-2012, 03:49 PM
thunderstruck507's Avatar
Without trimming back the covers and molding those to the fenders I think the end result will look somewhat "unfinished"
Old 08-28-2012, 07:38 PM
Striker289's Avatar
no output pictures yet. the one projector needs a bulb, It has a bad spot in it. Might not look 100% factory but that's impossible on cars like this unless you keep the flip ups.
Old 08-28-2012, 09:45 PM
ZROCWS6's Avatar
So the lids are always in that position? Thats got to look weird at different angles. It would be cool if they would be closed like normal and open only that far.
Old 08-29-2012, 07:47 PM
Restricted User
281green's Avatar
Looks great!
Old 08-29-2012, 10:29 PM
67goatman455's Avatar
maybe have a high and low beam projector?? seems like too much open space in there. but if you make some type of shroud then im diggin it
Old 08-30-2012, 08:51 AM
Striker289's Avatar
eventually id love to run two bi-xenon projectors per side. But right now im just recyling what i have lay around. Hope to get back on the project the weekend.
Old 08-30-2012, 10:24 AM
VIP1's Avatar
If you add a second projector, a Halogen High Beam projector may be a better idea than a second bi-xenon.
Old 08-31-2012, 08:37 PM
Striker289's Avatar
so i test drove it tonight. The Function is good. But my execution is lack luster. the frames for the covers work awesome but the Projector mounts and adjust ability Blows. Starting to think I need to find factory headlights that will be close to fitting in the gap i have set, Because it would be easier to adjust. I have the front of the lids about 3 inches from the bumper. Anyone have Ideas for housings?
Quick Reply: TA Fixed Headlight Retrofit
