GTO dash in chevelle
Old 09-01-2012, 11:16 AM
mdrn69velle's Avatar
Default GTO dash in chevelle
Finally got all the gto dash parts for a swap. Before I take out the Chevelle dash I want make shure I can make the GTO cluster work with a LS1 PCM. All I really care for is tach, speedometer, and temp. The rest would be nice. YES I did research heres some links I read up on
https://ls1tech.com/forums/conversio...ng-pinout.html
Has anyone made one work?
Also couldn't figure out what year the cluster came out of but I was told is a 6speed heres a pic if anyone can tell me what year it is that would be great.
Old 09-01-2012, 01:53 PM
01WS6/tamu's Avatar
On my chevelle I'm doing the same thing. But in a effort to make it easier as far as overall wiring goes. I am transplanting the complete car harness dash column and all into my chevelle so it's all plug and play.
It has been my experience that when you start mixing and matching especially on the engine electronics and interfacing into interior electronics that's where it becomes really sketchy. It becomes that way because depending on the pcm and the platform its programmed for the pcm sends out different info over the data bus.
The most bullet proof way to make it work if doing it in a piece by piece manner. Is to use a pcm programmed for a gto and make sure the year of the pcm and the cluster are the same.
Old 09-01-2012, 05:22 PM
lizeec's Avatar
I do know that the 2004 gto cluster is the one you need as that was the only GTO year model that came with a ls1, the 2005, 2006 GTO cluster are for ls2 with a totally different PCM (E40) One note though there is only 1 part number for each cluster in their respective year, wether it is auto or standard it is the same part number, I am not sure if the programming is in the cluster itself or the PCM that can make it read correctly for either auto or standard.
Old 09-01-2012, 06:58 PM
superdave84's Avatar
I want to see pics of this for sure.
Old 09-01-2012, 08:00 PM
I take it you have a LS2 with ECM and your gonna use the BSM and PIM. That is plug-n-play.....well I'm gonna have allot of homemade harness back there I have a Ls1 with a PCM and I also plan on using the Vintage Air System to work with the GTO HVAC controls. I know some here did it. I want to some how make a stand alone for the cluster. Like I mentioned, I could careless for the display, I'm more concerned for the gauges them self. Worse case I have to convert to a 24x or 58x I forget witch one is LS2? And change over to ECM?
I found a column for $75 with a key I plan on making it work like a old style turn over key, (no vats) if I have to ill put a old GM key in the key hole.
Yea thought that as well 04 is LS1, after looking at all the manufacture build dates stickers on the dash and HVAC controls I think its a 05/06 system, BUT he did say he sent me a spare cluster because he sold the original one on ebay.
I pulled the trigger early and said F*it, started cutting metal and dash is almost in. Stay tuned for a build thread I'm gonna make soon. I have enough pics to make you bored.
Old 09-01-2012, 08:59 PM
01WS6/tamu's Avatar
I got my paws on a rolled over 06 at auction and I am working on putting complete harness and every last module from the gto in the chevelle. The complete harness front to rear and left to right including functioning airbags and antilock brakes are goin in a 70 my brother and I are building.
We aren't close to working on wiring yet still working on fitting powertrain and then body and paint.
Old 09-01-2012, 10:56 PM
Nice. If you plan on installing the complete GTO dash I would consider tryna get it in before paint and especially windshield install. Im glad I did after the stuff I found, you will also be cutting allot of metal away to make it fit.
Old 09-01-2012, 11:22 PM
lizeec's Avatar
Check out a member here "kwhizz" he has a 37 Ford that he got a complete GTO cluster working properly in his car, also another member "samhatco" he put the GTO dash and cluster in a 69 firebird.
Old 09-02-2012, 12:16 AM
Yea I posted the 37 ford link on my first post I read up on his, I also PM'd "samhatco " to ask him some questions, he did a 02 LS1 swap with the gto interior. Thanks for your time.
Old 09-02-2012, 12:42 PM
chuckd71's Avatar
Would like to see pics of this as well, if it turns out even half as nice as samhatco's car it should be awesome.
Old 09-02-2012, 07:12 PM
01WS6/tamu's Avatar
We're both engineers so too damm picky for our own good if it's not perfect it won't leave the shop.
Old 09-03-2012, 03:10 PM
Anyone have any answers to my original post? Will the LS1 Tac wire run the GTO tac? What about the pcm VSS will it run the speedo? my t56 is out of a gto so don't know if that helps with the VSS sensor in the trani.
Old 09-08-2012, 07:19 PM
".." anyone??
Old 01-06-2013, 02:57 PM
A little update:
Chevelle dash is completely gone and cut away. I started trimming the GTO dash to fit the contour/ curve of the chevelle windshield. Yesterday I got a hold of a goat steering wheel and column with a matching key, so ill be installing that today. Now ill have a tilt and sliding column. I will replace the steering wheel so thats gonna go up on the market soon. The gauges project is still where I left off. (I haven't worked much on it since my last post) ill post pics and update more in the following days.
Old 01-06-2013, 03:30 PM
-TheBandit-'s Avatar
Check this out http://www.pro-touring.com/showthrea...-6l90-Chevelle
Old 01-06-2013, 07:28 PM
kwhizz's Avatar
My unit is 100% functional with the help of Eric Gonzalez.........Eric figured out how to get the ABS fault to go away.......Here's Erics Email..... americs01@gmail.com
.He can probably answer any question about these issues.........
Ken
Old 01-08-2014, 11:49 AM
Finally got all my dash mocked up and in. Wasn't easy, a lot of fitting and cutting, over and over. But I'm happy with it. Now going to make the door panels from the GTO ones so everything flows together. I tried uploading a pic thru my phone but it won't let me. Ill upload some later today. Figuring out the harness is going to be another nightmare.
Old 01-08-2014, 12:07 PM
Old 01-08-2014, 05:10 PM
Originally Posted by mdrn69velle
So awesome. Makes me want to rip out my dash and try it too.
Old 01-08-2014, 05:29 PM
86_irocz-28's Avatar
awesome build
Quick Reply: GTO dash in chevelle
