which guages??
which guages??
any suggestions on which 2 guages to fill my new pod??
I would like to get 2 I don't already have, but what do I know...
It is a 98 Z28, A4.
please help?? brands and types would help to.
It is a 98 Z28, A4.
I find the most useful to be Trans temp and Fuel pressure. Although the fuel press. gauge is about a $175, so you could just get an Air/Fuel ratio gauge to fill the hole until you find a gauge you really need.
I have purchased Cobalt gauges by Autometer. Light up blue @ night.
I have 3 gauges.
Top: Trans Temp
Middle: Air/Fuel
Bottom: Water Temp
http://community.webshots.com/photo/...23944199DZYvkk
I recommend getting Trans And Water Temps.
Stock water temp is crap, aftermarket is much more accurate.
I have 3 gauges.
Top: Trans Temp
Middle: Air/Fuel
Bottom: Water Temp
STF Veteran
Water temp is a must, I also have an A/F, and voltmeter due to several electrical modifications and the fact that my baby is a garage **** that sits on a trickle charger at all times. I used all Nordskog red LED guages that black out when off and match perfectly to the Pontiac red.
Originally Posted by black02TA
Thanks.. They are a little bright though.
And I'm doing the same install (same gages) next week. Any pointers or instructions? I know about the Trans and water temp (fittings), but I'm not sure how easy the A/F is. Right to the PCM?
Thanks, Ski
Originally Posted by 666ws6
Someone over on LS1.com had problems with two of tha gages not lighting up the same brightness.
Thanks, Ski
Thanks, Ski
