So my 98 has a plastic gas tank!
Old 09-01-2012, 11:44 PM
Marios_98z's Avatar
Default So my 98 has a plastic gas tank!
My fuel pump went out so I went along and did the trap door to my surprise as I was done and lifted the piece I had cut the pump was no where to be found this sucks! Now I have a bigger door then I would've had had I known the tank had been switched who knows why it was switched!!
Old 09-02-2012, 12:27 AM
Mean87SS's Avatar
Oh...
Old 09-02-2012, 01:48 AM
6898camaross's Avatar
Cool story bro.
Old 09-02-2012, 12:27 PM
Marios_98z's Avatar
Originally Posted by 6898camaross
Cool story bro.
Yeah just thought I'd share a little bit of my frustration!!
Old 09-03-2012, 03:16 PM
14k
14k's Avatar
Thought 99 got the steel tank 98 had plastic tank.
Old 09-03-2012, 03:26 PM
Trunion King
bene's Avatar
Big negative.
Old 09-03-2012, 03:30 PM
garygnu's Avatar
my 2000 has a plastic tank.my 80 vette has a plastic tank inside a steel shell.no leaking from rusting.
Old 09-03-2012, 03:33 PM
ULTIMATEORANGESS's Avatar
exactly. the straps they used on steel tanks would rust too. plastic is also lighter.
Old 09-03-2012, 08:15 PM
14k
14k's Avatar
http://www.southernfbody.com/threads...ferences.1999/
98
Last year F-body to use the old 15.5 gallon steel fuel tank.
99
witch to larger 16.8 gallon plastic fuel tank to meet new emissions requirements.
Soooo where my big negative at ghost rider?
Old 09-07-2012, 01:21 AM
Re-read your original post ^^^^
Old 09-07-2012, 02:11 AM
Trunion King
bene's Avatar
98
99
Originally Posted by bene
Big negative.
What he said.
Old 09-07-2012, 02:22 AM
LS1Tech Administrator
RPM WS6's Avatar
Received 1,794 Likes on 1,278 Posts
LS1Tech 20 Year Member
Old 09-07-2012, 03:51 AM
01ssreda4's Avatar
dyslexia or should I say.....aixelsyd
Old 09-07-2012, 04:14 AM
AronZ28's Avatar
So why didn't you do this repair the proper way and drop the gas tank???
It really isn't any more effort and you don't have a hacked up floor. Plus I'd be awfully afraid of cutting through the floor AND the gas tank with a plasma torch, thus blowing myself up from gas vapors.
Old 09-07-2012, 07:38 AM
1badSS's Avatar
Step back! You are speaking with logic and reason, this is not allowed. On a serious note I never understood this thought of hacking the floor, just drop the tank.
Old 09-07-2012, 09:01 AM
Stu_x24x's Avatar
I dropped the tank in my 98. Wasn't too bad. We had some troubles wrestling the tank filler neck out and in, but it all ended up working out. I wasn't too keen on cutting up my floor and figured if I was going to change the pump/regulator, might as well do it right.
Old 09-07-2012, 10:31 AM
RPM WS6's Avatar
I would not drop the tank again. GM should have put an access door for this, I would see it as correcting a factory mistake. For those of us that don't have a lift, this method is MUCH easier than dropping the tank, and once the panel is cut then future replacements are even easier still. Dropping the tank even with a lift is a pain in the *** IMO.
Who uses a torch for this? The floor is thin, you can drill shallow access holes and cut the rest with tin snips even.
Add a patch panel when done, sealed with some short sheet metal screws and silicone or rope caulk, cover it back up with the carpet and forget about it.
Old 09-08-2012, 01:53 AM
myk
myk's Avatar
Meh, if the girlfriend's cute little Ford Escape can have a trapdoor that allows me to swap the pump in a few minutes then a street racing legend like our cars should have one too. I will say that I wasn't PROUD of what I did, but hey...
Old 09-08-2012, 01:59 AM
Lee12609's Avatar
everyone that says do it right and drop the tank has never had 3 pumps fail in 6 months!
thats all i'm gonna say.
Old 09-08-2012, 02:47 AM
transamtom's Avatar
You either have the worst luck ever or you drive around with a 1/4 tank or less all the time.
Quick Reply: So my 98 has a plastic gas tank!
