88 coupe mustang with ls motor FS OR FT
Year: 1988
Make: Ford
Model: Mustang
Price: $9500
Mileage: 0
Private or Dealer Listing: Private Listing
Location (State): TX
Color: White
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Asking 9500.00 or trade for something of equal value.
08 ly5 55k miles
milled 243's
comp custom grind cam
dual 650 valve springs
hardened pushrods
(Built)th350
neil chance 4200 stall converter
B&M shifter
B&M Trans cooler
Lakewood 90/10 shocks with rear coil overs-have 3 sets of springs
Competition Engineering Struts with front coilovers
AJK k-member
new starter
new battery
Elderbrock Vic Jr Carb intake
MSD 6012 box
ls swap headers with v bands
sumped tank with -8an feed line
Summit carb pump with russel filter all -an fittings
850 cfm 4150
6.0 coils-one new coil i bought from oriellys-lifetime warranty
flaming river steering shaft
strange th350 yoke with conversion u-joint
Steeda driveshaft spacer for correct yoke engagement
3" true duals into race bullets
innovate wideband
autometer water temp gauge
autometer oil pressure gauge
Modified 3g 1 wire alternator to fit ls brackets
painless fan controller
Tubular rear upper and lower control arms with poly bushings
Rear sway bar
3.73's( car cruises about 65 @ 2800)
MM caster chamber plates
Steeda bumpsteer kit
FRPP hood pins
drilled slotted rotors
Welded lower torque boxes
Draglite wheels with 26/11.50 in back
f-body radiator
f-body fans
Heater works
Ac stuff is still under dash
P/S
pm if interested.
- 6 liter short block has 50k miles
- fresh portedLS3 heads with PRC EHT .675" springs
- ARP Bolts
- all Gaskets replaced
- LS7 lifters
- Hardened pushrods
- New LS6 oil pump
- TSP 231/236 .641''/.615'' LS3 cam.
- LS3 intake with a edelbrock 90mm tb
- Under drive crank/alternator pulley
- New AC system
- New Serp Belt
- New ac tensioner
- New serp belt tensioner
- New idlers
- Electric fan over ride switch
- SLP air lid
Exhaust
- TSP 17/8" ceramic coated headers
- duals into a bassani x pipe into a 3" Y into a 3" magnaflow
Transmission
- 4L65E Trans Built by Top Gear Motorsports in Az, Has a beast sun shell with all upgraded clutches/steels/ servo ect
- Edge 4k nitrous converter, anti ballooning plates ect
- Trans has 500 miles on it since rebuild
- Rear is the stock 10 bolt with a 3.73 gear, diff cover, factory SLP Posi
- Trans cooler
Chassis/Suspension
- UMI K member
- UMI tubular front upper and lower control arms
- adjustable QA1 coilovers up front
- UMI solid motor mounts
- UMI 3point sub frame connectors
- UMI tunnel mount torque arm
- UMI adjustable panhard bar
- UMI Rear adjustable control arms
- UMI Rear Control Arm Relocation Brackets
- rear shocks are adjustable comp engineering.
Wheels/Tires
- 3" extended stud all 4 corners
- Summit Drag thrust wheels
- ET Street radials in 275/60/15 in the rear
- 26/7/15 MT radial front runners.
Brakes
- Front and rear new cross drilled and slotted rotors
- Front and rear new brake pads
Fuel
- Racetronix pump
- Racetronix hotwire kit
- stock ls1 injectors
- ARP Bolts
- LS7 lifters
- Hardened pushrods
- New LS6 oil pump
- New AC system
- New Serp Belt
- New ac tensioner
- New idlers
- SLP air lid
Exhaust
Transmission
- Trans cooler
Chassis/Suspension
- UMI K member
Wheels/Tires
Brakes
Fuel
- Racetronix pump
Has it been on a dyno, if so what kind of power is it making. Been to the track, if so what kind of times is it running and what is the compression ratio?
Thanks
Mike
Thanks
Mike
