IAT placement
Old 09-04-2012, 09:09 PM
Taubr Unit's Avatar
Default IAT placement
So opposed to putting the IAT sensor in the charge pipe like all other kits, is it ok and will it work fine if I put it on the back side of my elbow from Aaron? dumIf ya will the computer still read it correctly or will I get funky readings?
Old 09-04-2012, 09:11 PM
pwrtrip75's Avatar
I would think as long as you are getting an accurate reading of the air temp going in it would be fine.
Old 09-04-2012, 09:13 PM
Moderator
denmah's Avatar
dont over think it, just jam that thing in somewhere haha.
Old 09-04-2012, 09:17 PM
Taubr Unit's Avatar
Haha that's what I was thinkin' Figure before I go hoggin' out my elbow I'd ask first incase someone did it and it worked like ***.
Old 09-04-2012, 09:31 PM
Moderator
denmah's Avatar
i put em in the intake great place for them
need ideas? is it a ls1 intake?
Old 09-04-2012, 09:37 PM
Taubr Unit's Avatar
No, Vic jr with a Sheet metal 6061 elbow. The back of the elbow has 3 untapped boss's on the back side so I was gonna tap one of um and screw the IAT on the back side of elbow.
Old 09-04-2012, 09:46 PM
Moderator
denmah's Avatar
oh yeah in the elbow would be the **** for sure
Old 09-04-2012, 09:47 PM
Slow94Formula's Avatar
Not to hijack, but since this came up... Would it work to put the IAT sensor in the stock MAP sensor location on an LS3 intake? Or would it not really get a good reading?
Old 09-04-2012, 09:53 PM
Moderator
denmah's Avatar
hell yeah i would drill it and glue it in there
Moderator
denmah's Avatar
thats nearly where i put it in the ls1 intake, i pop that pcv stuff out and use 2 part epoxy right in the side of the intake neck right next to the throttle
Old 09-06-2012, 10:38 PM
Beanslsxnova's Avatar
Haha denmah! You sir are the Clark Kent of ls1tech hands down.
As far as the Iat in the elbow, a buddy of mine has his in the side of his elbow and it works great. Looks clean to
Old 09-07-2012, 12:37 AM
Taubr Unit's Avatar
Ya that's exactly what I'm thinking, look super clean hidden behind the elbow and won't have a wire jetting across to the charge pipe.
Old 09-07-2012, 10:56 PM
Moderator
denmah's Avatar
Old 09-07-2012, 11:00 PM
Moderator
denmah's Avatar
you can see where mine is right behind the throttle on the passenger side, 2 part expoxied in there.
Quick Reply: IAT placement
