Need tips on painting my aluminum block
Old 09-05-2012, 02:03 PM
Houston_t's Avatar
Question Need tips on painting my aluminum block
Followed my standard procedures for painting steel ( cleaned the crap out of it, scotch bright, cleaned again with break cleaner, sprayed with high temp paint 3-4 light coats ) but the paint is flaking off is some places and I haven't even fired up the engine yet. Is there something I can spray on it to get it back to bare metal, and once I do how should I prep it for a respray ?
Should I had used self etching primer first ?
Old 09-05-2012, 02:21 PM
ULTIMATEORANGESS's Avatar
isnt there paint designed for aluminum blocks?
Old 09-05-2012, 04:21 PM
Houston_t's Avatar
I'm not sure I just assumed you painted them like anything else untill I painted it.
Old 09-05-2012, 04:46 PM
00ZNewb's Avatar
clear coat it and let that aluminum shine!
Old 09-05-2012, 05:39 PM
garygnu's Avatar
try epoxy paint.
Old 09-05-2012, 07:13 PM
I8UR4RD's Avatar
just regular old engine paint from the auto store. wipe the block down with 180 grit, and then wipe that off, and spray. the sandpaper will remove bullshit that wont usually come off. as far as clear that **** will just end up cracking.
Old 09-14-2012, 12:15 PM
Superspook1's Avatar
I'm new on here but got a lil knowledge of painting. To do an engine right & for the paint to last I used a urethane paint with hardner
Old 09-14-2012, 12:18 PM
To get paint to stick to aluminum you definitely want to use a self etching primer. Clean all parts with degreaser then use a wax & grease remover prior to painting. Hope this helps. Reason why I'd recommend the urethane paint with hardner
Old 09-14-2012, 12:23 PM
It will stand up to any chemicals as far as oil, gas, & basically anything else used around your motor. Good luck with your painting
Old 09-14-2012, 12:57 PM
Houston_t's Avatar
I'm looking for something I can spray out of a can. Don't have a compressor in my garage as of yet
Old 09-14-2012, 12:58 PM
Houston_t's Avatar
Will self etching primer hold up to the engine heat ?
Quick Reply: Need tips on painting my aluminum block
