Has anyone seen their oil pressure gauge do this?
I did a search on bad oil pressure sending unit symptoms, but all I found were threads pertaining to too high or too low of a pressure reading. Today as I was driving home from picking up dinner, I noticed my oil pressure was, "bounching around" and very...jolty. It's never been like this before, but the pressure itself is well within "optimal" range. Should I be worried about a pump going out, or is it safe to say it's probably just a weak sender? The car has 133K miles, with I'm sure both a stock pump as well as a stock sending unit.
Sorry about the rough video quality, but if you view it in full screen you can see what I'm talking about pretty good.
Not to mention the knockoff at my local parts store is 15 bucks more than the delco one!
Thanks for the input, I'm making a 180 mile drive tomorrow and I didn't want to have to worry about a pump going out.
Thanks again!
Thanks again!
As the others have said it's definetly the sending unit. Also - get the ACDelco Sending unit. I just had this same exact problem on my 6.0 LQ4 in my Silverado and replacing the Sending Unit did the job.
