rear axle & pinion angle question
Old 09-06-2012, 02:34 PM
1 FMF's Avatar
Default rear axle & pinion angle question
for a stock setup what controls pinion angle? Is there an adjustment or is it factory set? Reason i ask is I am getting an S60 and will be installing it myself. Also doing new oem motor mounts and oem transmission mount, and an energy suspension torque arm mount. I am reusing the oem torque arm, panhard bar and LCA's for now. When i pull the 10-bolt out and get the S60 in and bolted up, is all i need to do is bolt it up and am I supposed to expect to have a correct pinion angle? Or specifically that the transmission tail shaft will be parallel with the pinion yoke? And if it isn't, then where/how would I make adjustments with the stock suspension stuff?
thanks.
Old 09-06-2012, 02:40 PM
01ssreda4's Avatar
Can't adjust with the stock stuff. It should be close enough to get you by until you can upgrade.
Old 09-06-2012, 03:03 PM
blackjack325's Avatar
while on this subject, does lowering the car affect pinion angle? if so, might that cause a vibration while driving?
Quick Reply: rear axle & pinion angle question
