rear axle & pinion angle question
for a stock setup what controls pinion angle? Is there an adjustment or is it factory set? Reason i ask is I am getting an S60 and will be installing it myself. Also doing new oem motor mounts and oem transmission mount, and an energy suspension torque arm mount. I am reusing the oem torque arm, panhard bar and LCA's for now. When i pull the 10-bolt out and get the S60 in and bolted up, is all i need to do is bolt it up and am I supposed to expect to have a correct pinion angle? Or specifically that the transmission tail shaft will be parallel with the pinion yoke? And if it isn't, then where/how would I make adjustments with the stock suspension stuff?
thanks.
thanks.
