any lowered 4th gens with BMR Trak Pak Torque Arm??
like stated, any lowered 4th gens with BMR Trak Pak Torque Arm?? wanted to know if you have any ground clearing problems and so forth
thanks
thanks
LS1Tech Premium Sponsor
I have a few local guys that use our BMR Trak Pak on lowered cars without any issues but you will have to be careful over speed bumps and other onstacles. There are a couple of things you can do to maximize ground clearance, the first would be to have us send a straight crossbrace rather than the one with the bend which will give you more ground clearance but less exhaust clearance. The second thing is that you can pivot the crossbrace prior to welding to get a little more clearance out of the crossbrace with the bends int it.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
![](https://ls1tech.com/forums/signaturepics/sigpic136487_1.gif)
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
We cannot guarantee that because all exhausts hang differently. It's usually best to install the bent crossbrace and rotate it as much as you can to gain some clearance or modify the exhaust.
When I installed mine, I had a custom X-pipe made to curve into the dip in the crossbrace. It worked really well and had a minimal impact on clearance.
