LS2 GTO front mount single low budget turbo, keeping A/C
Old 09-07-2012, 11:43 PM
ACCLR8N's Avatar
Default LS2 GTO front mount single low budget turbo, keeping A/C
One person anyway wants to see what I'm doing so that's enough excuse to start a thread I think. 2005 LS2 M6 GTO. Modest goal of adding a hundred horse to the wheels without affecting driveability or comfort. 5-6psi of boost with lots of ebay parts. Not moving the battery and I'm keeping A/C. I can't believe how much of the budget went to mandrel bends.
DNA GT45 69mm turbo T4 1.05AR
44mm wastegate
50mm BOV
27"x9"x4" intercooler
Modified truck manifold
2.25" crossover
3.5" downpipe
3" cold side tubing
60lb Siemans Deka injectors
Deatschwerks DW65C fuel pump
EFI Live
Attached Thumbnails LS2 GTO front mount single low budget turbo, keeping A/C-gto_turbo_engine.jpg
Old 09-08-2012, 12:16 AM
ACCLR8N's Avatar
Default Manifold
Started with the very common flipped passenger truck manifold. Sch40 mild steel weld el welded on to support the T4 flange. The nodular cast iron manifold have very low thermal expansion so I went with the heavy wall mild steel to better match it. The flange was positioned to allow room for an air filter.
The particular manifold I used is from a 2008 5.3L pickup 12616288. If I did another one I'd consider using the Trailblazer SS 12600527 manifold. It is tighter to block providing an extra 11mm for downpipe. The negative is the exit is more downward making it harder to turn up to the flange.
Attached Thumbnails LS2 GTO front mount single low budget turbo, keeping A/C-5_3l_pass_manifold.jpg   LS2 GTO front mount single low budget turbo, keeping A/C-manifold_joint_small.jpg   LS2 GTO front mount single low budget turbo, keeping A/C-manifold_pianted_small.jpg   LS2 GTO front mount single low budget turbo, keeping A/C-manifold_wrapped_small.jpg
Old 09-08-2012, 12:22 AM
pairof69s's Avatar
very clean n simple....I likey
Old 09-08-2012, 12:36 AM
ACCLR8N's Avatar
Default Passenger Side
Thanks
I'm using the GTO driver's side manifold on the passenger side with a spacer exiting low and forward. The spacer provides clearance between the manifold exit and the motor mount bracket. The spacer is a 3/8 header flange with small ports so I could match it to the manifold.
Attached Thumbnails LS2 GTO front mount single low budget turbo, keeping A/C-pass_manifold_small.jpg   LS2 GTO front mount single low budget turbo, keeping A/C-crossover_mtr_mnt_small.jpg   LS2 GTO front mount single low budget turbo, keeping A/C-spacer_port_match.jpg
Old 09-08-2012, 06:22 AM
a4ls2goat's Avatar
Very nice I like it.
What fuel will you be using?
Old 09-08-2012, 09:24 AM
LS1NOVA's Avatar
Very nice, I like it.
Old 09-08-2012, 09:37 AM
ACCLR8N's Avatar
Default Crossover 2.25"
Thank you. I'll be running 93 octane pump gas. Keeping it simple.
Crossover is 2.25" mild steel again. Ceramic baked on paint and DEI Titanium wrap. The pipes have been ovaled slightly for more clearance. After moving the starter harness behind the compressor and over the motor mount I was able to snake the exhaust from the passenger side around the front of the mount. The exhaust is not under the compressor. The second driver's side piece is a pretty simple L going up into the merge above the alternator. There is going to be a big notch in the skid plate for the passenger side to exit. The whole mess is higher than the low point on the skid plate, but well bellow the radiator hoses and wiring across the front.
Attached Thumbnails LS2 GTO front mount single low budget turbo, keeping A/C-crossover_frame_small.jpg   LS2 GTO front mount single low budget turbo, keeping A/C-crossover_o2_small.jpg   LS2 GTO front mount single low budget turbo, keeping A/C-driv_clrnc_small.jpg   LS2 GTO front mount single low budget turbo, keeping A/C-ground_front_small.jpg
Old 09-08-2012, 11:36 AM
a4ls2goat's Avatar
You should throw some 317 heads in there for safety
Old 09-08-2012, 11:59 AM
josepy121380's Avatar
Love the build.
5-6lbs I do not think it is worth. Granted I do not know much on the ls2's My forged ls1 has prc 5.3 heads 10.3 to 1 compression and I am running 16lbs on a f1c. It loves it. 93 pump gas with only 14 degrees timing and meth for cooling.
Old 09-08-2012, 12:47 PM
RacerXLs1's Avatar
Looks good, that 6psi is only going to last a week.
Old 09-08-2012, 07:30 PM
6PntHo's Avatar
I like it.. I bet your going to turn up the boost after awhile lol.
Old 09-08-2012, 10:11 PM
ACCLR8N's Avatar
I'm not planning on even taking the valve covers off. At the moment the wastegate only has 4psi spring in it. I'll ramp it up a couple more but the plan is to keep it under 600 crank HP. Stock clutch is doomed but the rest of the drivetrain is expected to survive on this street car. I can't afford to go any faster.
I'm not doing this because I felt the car was slow. I'd like it to be as fast at a lower RPM. I don't like red lining my vehicles. Plus I've always just wanted a turbo car.
Old 09-08-2012, 10:34 PM
a4ls2goat's Avatar
the bottom end will take 600whp no problem.
you can also throw in a LS9 cam for cheap.
Old 09-08-2012, 10:57 PM
ACCLR8N's Avatar
Default Downpipe 3.5"
The ugly: The pinch between the frame and the truck manifold required severe ovaling of the downpipe. This ate up a lot time for me. To protect the steering rack the pipe is wrapped and has a SS heat shield bolted to it. On the body, I removed the frame brace mount and took a Ford wrench to the rearmost crush wrinkle to maximize space.
Attached Thumbnails LS2 GTO front mount single low budget turbo, keeping A/C-downpipe_pianted_small.jpg   LS2 GTO front mount single low budget turbo, keeping A/C-pwr_str_shield_small.jpg
Old 09-08-2012, 11:10 PM
a4ls2goat's Avatar
Where you putting your feed/drain
Old 09-08-2012, 11:47 PM
ACCLR8N's Avatar
Default Turbo oil feed and drain
I used the existing plugged port at the rear of the pan for my supply oil. It's metric M14 x 1.5 thread. The Russel fitting I got was very loose and was never going to seal on the threads. I had to find a Teflon washer that was thicker than the flange of the adjacent mounting bolt. The washer took some whittling to make it fit. Eventually it provided a sealing face for the fitting to tighten against. No leaks so far. -4AN line.
I botched the oil drain. It is in a bad location. It should be much further rearward. To keep it away from the manifold, two holes were drilled so the -10AN line passes through the frame rail with a couple grommets. It has the reflective heat sheathing and makes a big U going behind motor mount in picture. It should have gone straight into pan rear of the motor mount.
Attached Thumbnails LS2 GTO front mount single low budget turbo, keeping A/C-oil_supply_small.jpg   LS2 GTO front mount single low budget turbo, keeping A/C-oil_output_small.jpg   LS2 GTO front mount single low budget turbo, keeping A/C-pan_drain2_small.jpg   LS2 GTO front mount single low budget turbo, keeping A/C-oil_drain_wires_small.jpg
Old 09-09-2012, 12:05 AM
a4ls2goat's Avatar
Looks good.
Old 09-09-2012, 12:58 PM
a4ls2goat's Avatar
this is how i did my feed
my return
Old 09-09-2012, 05:12 PM
ACCLR8N's Avatar
Like the supply a lot better. I wasn't TIG welding yet when I did mine.
Old 09-14-2012, 10:42 PM
ACCLR8N's Avatar
Default Power Steering Lines
The position of the turbo flange interfered with the power steering lines. I can't imagine how Holden decided it was cheaper/faster/easier to leave the system routed to the right side and turn the lines around and send them back to the left for our LHD market. I ended up tossing the pressure line altogether and flipped the cooler around. The cooler was able to mount backwards on the original brackets. Every piece was molested or outright replaced. Aeroquip power steering lines and fittings were back ordered so I went with Russel. I prefer the Aeroquip stuff.
Attached Thumbnails LS2 GTO front mount single low budget turbo, keeping A/C-pwr_str_t4_small.jpg   LS2 GTO front mount single low budget turbo, keeping A/C-pwr_str_press_small.jpg   LS2 GTO front mount single low budget turbo, keeping A/C-pwr_str_cooler_flipped_small.jpg
Quick Reply: LS2 GTO front mount single low budget turbo, keeping A/C
