line pressure
line pressure
Where in hp tuners do I go to find the line pressure settings for my 4l65e transmission? I think the tuner raised the line pressure after my dyno session.
Tampa Tuning Camaro Corvette GTO GM Trucks performance tuning
Go to the transmission tab/ auto shift properties/ Click on shift pressure.
If I increase line pressure, I increase it 5 pounds at a time till im happy.
www.TampaTuning.com
Phil
www.TampaTuning.com
Phil
what is the limit on the pressure for those tables. I know it is kind of hard to answer that question cause the warmer the fluid gets the higher the pressure is.
I cant seem to get the shift firmness that I want. Does some of that have to do with the servo also?
1 Post
No, actually, the colder the fluid is the higher the pressure is... there are tables that compensate for temperature as well. The firmness can be effected by the condition of the transmission as well - you can jack the pressure way up on a worn out trans and it won't be firm...
1 Post
If you compare them, stock pressures are not that much different - no, they aren't built different depending on what the stock line pressure is. The point is if you run elevated line pressures in a built trans you will break ****...
Then you must not look at too many different platform files. There is as much as 12 PSI difference just between 98 and 02 F-body tables in the middlre of the tables and the GM trucks can vary even more. Just between Denalis and Silverados of the same MY there can be big differences in the pressure tables. Silverado SSs and Hummers will have a lot higher stock pressures than regular trucks.
The trans is rebuilt with probably about 5k on it.....everything has been upgraded except for the servo. There was no trans kit put in it. Only thing for the valve body was the intermediate servo release check valve and was drilled out to the size per chart that came with the rebuild kit. Think is was 0.028 or something like that.
