Why is a 5.3l w/317 a slug?
What engine with 8.6:1 compression isnt a slug? People are under the impression that turbos need low compression. Probably true if you are trying to run 30psi on pump gas.. But if you had a turbo to achieve that and you are running a stock 5.3 odds are it would fly apart well before that...lol. So no need to lower the compression to prepare an engine for something it will never see. I did this also....it sucked. lol.
An 8.5 5.3 without a turbo is like a 150-200 hp combo... so there's your sluggish right there.
Do you have data that says a lower static 5.3 with more pressure is more efficient then a 10:1 5.3 with a t76? What makes you think it will "pick up top end"?
Convertor stall
Rear end Ratio
Ar. of exhaust housing..
ok so let me see if i get this right... i got a 5.3l with 317 heads, ls6 cam, and flat pistons.. which should be 9.5:1 comp right?? should i swap into ls1 heads for better results or turning the boost up at lower rpms should even it out??
Grr, can you explain the dynamic CR and how you calculate the DCR and STR? Thanks
Also, I understand the significance of STR, but what is an ideal DCR for a street vehicle and how does that play into driving or response. Im sure Im not the only one who would find this info useful
