Using truck coil packs with ls1 rail
You wouldn't happen to have a pic would you ? Might help with ideas . I was going to use spacers under the coil mounts to raise my coil packs up farther away from the valve covers for clearance with my headers , but I am not sure that will work in your case .
Gently bend the fuel rail to clear. Just be careful not to kink it. Put a screwdriver in the tube and go slowly. Heat will help, but this may not be an option for obvious reasons.
A little kink may be ok if you're not running a big HP engine. My 5.3 didn't care at all, but I ended up with a new rail that I bent more carefully, so its all smooth now.
