Which gear oil
Which gear oil
From what I understand if you have a Gorden differential you don't need the limited slip additive. How do I know which diff I have? Do I need to use synthetic, or non synthetic? Which oil weight? I have an 02 Ws6.
The torsen has several gears in the diff unit that you can easily see. If you can't see gears in the diff unit you should use LSD additive. Or you can use it anyway - it won't hurt the Torsen from what I've read
I have a 02 z28 with 4.11's, do I need the additive? I didn't do the gears bought the car with them and im about to do a girdle and want to make sure I use the best gear oil to get the most out of it
