fluid
fluid
so i tried searching and couldnt come up with the exact answer. i have a FLT level 4 (4l60e) i just bought with 10K miles on it. it has fluid in it but not full because a bunch of it spilled out. im also install a SS3600 converter. the motor and trans are out of the car and i am wondering how much fluid i need to put in? i thought i read somewhere that you only check trans fluid while the car is running. well obviously i can't do that... i also read that it is VERY dangerous to run the car with low trans fluid even for a split second...
any help?
any help?
You can fill it till it come out the overflow/vent tube. I pesonally would just drain it and throw a new filter in it and start with the fluid from scratch. Fill the converter before you put it on just incase you didn't already know that
Moderator
Someone correct me if I am wrong....
Just before starting the car, I would add trans fluid until it reads about 1 inch above the full line, obviously with the engine NOT running. That should get you pretty close.
The trans and converter together will hold about 12 quarts. After a complete rebuild, I start by adding 10 quarts and go from there. I don't think it hurts to be 2 or 3 quarts low when you first start up.
the filter was just changed at the beginning of spring with only a few track passes on it so i really didn't want to replace it again if it's not needed.
how much fluid should i pre-fill the converter with?
Moderator
Try to get at least one quart in. Since you have to turn it sideways to install it, a bunch will spill out, so there is no need to fill it to the very top.
Moderator
After you "think" the converter is fully installed, put a straight edge over the bell housing and measure the distance to the converter mounting pads. On a 4L60E for an LS engine, it should be 1" - 1-1/16". Less and the converter is not fully in. More and you may need to install washers between the converter and flexplate.
