cost to check pushrods
Old 09-20-2012, 11:48 AM
ccdominic's Avatar
Default cost to check pushrods
Shop quoted me 140 (2hrs) to tighten to rollers and check the push rod length
Should they be able to that in an hour?
Old 09-20-2012, 11:56 AM
FiredUpZ28's Avatar
140 for 2 hours is pretty cheap no matter what way you look at it. An hour is a little tight.... maaaaybe 1.5 at the lowest. Regardless if you wanna brutally honest answer - if you cant do it yourself then technically they can charge what they want. Having said that, not every shop will charge the same labor. AllData is a guide but we dont quote direct alldata time mostly because that stuff is written as if the cars are brand new.
Old 09-20-2012, 12:33 PM
ccdominic's Avatar
...and free market says i can always go to another shop if they wanna charge whatever they want lol. but i have no experience in adjusting this, and so i want it done right because i dont wanna ruin my engine by dropping a valve or something. i just wasn't sure if i'd regret not posting and someone later on saying ah man, a shop should of been able to knock that out in 15 minutes. but thanks for the response. i just always check others input before proceeding.
Old 09-20-2012, 04:50 PM
imma_stocker's Avatar
Flag hours, end of story.
Old 09-20-2012, 05:23 PM
LS1Tech Premium Sponsor
Sales3@Texas-Speed's Avatar
You can always get a pushrod length checker (we have them for $20.00) and check the length yourself. It would probably take a total of 15 minutes to do yourself with the tool. Feel free to give me a call, I can definitely walk you through it.
LINK:
https://texas-speed.com/p-275-comp-c...h-checker.aspx
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old 09-20-2012, 08:33 PM
ScottyBG's Avatar
Why are you checking it, did you have a heads or cam swap done? Is your valve train noisy? If so, whoever did the swap for you should have checked it?
Old 09-27-2012, 08:44 PM
Jovozx12's Avatar
I agree with Texas Speed. Buy the tool and do it yourself. Its not that hard. You will save some money and it always feels better when you can say you did it yourself.
Old 09-27-2012, 09:20 PM
garygnu's Avatar
do you want to check for straightness or length.you can do it your self if you want .
Quick Reply: cost to check pushrods
