1975 nova ls1 5.3
1975 nova ls1 5.3
Any ideas on what kind of headers and exhaust I should use? I know everyone asks this but I've done a lot of searching and can't seem to find anyone with the same type of car. Thanks
Stock truck pan will hang too low... you'll destroy it.
I'm running a 5.3 in my 77 nova and use a CTS-V pan, Also used stainless 4th gen fbody ebay headers, bent them to fit my car better with a oxy torch. 1 3/4 primaries to 3" dual exhaust with moroso spiral flows dumped at the rear axle.
Just an FYI, all 2nd gen Camaros use almost the exact same subframe, only difference is where the bumper mounts, so you might try searching them. I have a 77 camaro subframe.. but I'm running ls1 manifolds. Also an f body pan, it doesn't hang below the crossmember at all.
LS1Tech Sponsor
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
How many of you had to cut and notch your subframe? Using the cts-V pan and carshop 1" setback plates, I didn't have to cut and weld ANYTHING, even reused my stock trans crossmember for the 4l80e. No clearance issues, fram or trans tunnel mods besides AN fitting access panels for my trans cooler.
header and oil pan clearance
Engine bay
Engine bay
