Dah, hood will not close with truck intake
Old 09-25-2012, 06:24 PM
superdave84's Avatar
Default Dah, hood will not close with truck intake
ok, so my hood won't close over the giant truck intake. Other than a cowl hood, what is my cheapest option to fix this?
Old 09-25-2012, 06:50 PM
3rdgen92maro's Avatar
Pick up a used ls6 intake and fuel rails is what i would do.
Old 09-25-2012, 06:52 PM
That's what I want to do...but don't I need a new TB, injectors and all new accessories too? I am running low on funds for this endless money pit.
Old 09-25-2012, 08:29 PM
chuckd71's Avatar
What is your current engine and accessories situation?
Old 09-25-2012, 08:30 PM
bczee's Avatar
How much do you need? I can suggest three options to try. But this was a known given the you might or would have hood clearance issue with using. A truck intake. As stated, to to a car intake. Older LS1 intake setup are pretty cheap.
1) You can try and shave any unused flange, ridge and threaded boss. That might get you some room.
2) You can also try and flatten or remove the inner flanges of the hood.
3) Lower the engine/trans
BC
Old 09-25-2012, 08:31 PM
Everything is stock, 5.3 from a Yukon. The only change is I put LT headers on it
Old 09-25-2012, 08:35 PM
BC
I will look into 1 and 2, but I can't go any lower with the engine. It's hovering about 3/8 above the crossmember.
Oh and I need like 3/4" or more. Just a guess though, I don't have the car here to measure exactly
What are the bare essentials needed to swap in the LS1 intake? Do I need to change throttlebody, rails, injectors, water pump, alt, power steering pump and all bracketry? Or is there a cheaper solution?
Old 09-25-2012, 09:04 PM
garys 68's Avatar
What year truck? 3 or 4 bolt TB? Flexfuel?
05 L59, $35 LS1 intake with stock 3 bolt TB. Aftermaket rails ($99), but the truck rails would work. modified truck PS.alt bracket.
Old 09-25-2012, 09:10 PM
2002 Yukon 5.3 L59 Flex Fuel. Unsure about the TB but will check tomorrow. Where did you find the LS1 intake so cheap? Or is that a typo?
Old 09-25-2012, 09:24 PM
bczee's Avatar
That is no typo.. most are People are looking for the LS6 intakes ($300-$350 normally).
Many of those looking and have swapped them in are LS1 engine as it is just about a direct swap for them and usually dumps the LS1 pretty cheap..
Check eBay, Craigslist and some of the other Forums for sale sections.
BC
Old 09-25-2012, 10:46 PM
454ragtop's Avatar
Keep in mind, you may have to change to a car style water pump also, outlet out the front instead of out the top.
HTH, Jim
Old 09-25-2012, 11:07 PM
i r teh noobz's Avatar
The truck cable throttle is pretty much the same as the LS1. It will bolt right on to the car manifold.
This is a bit dated, but should give you some ideas:
http://www.performancetrucks.net/for...e-swap-359987/
Old 09-26-2012, 12:35 AM
gofastwclass's Avatar
With a little creativity the car intake can be run with the truck water pump. Here are pictures of what I did:
Option 1 (my way):
Details of what I did are here...
To make my method work, you can not use the F-Body throttle body, it HAS to be a truck throttle body. Truck throttle bodies have a smaller "wheel" than the F-Body throttle body which won't interfere with the water pump as much.
Option 2 (the high $ way):
Buy a throttle body spacer which moves the throttle body forward .5 to .75 inches. This clears the upper water neck but cost money and I didn't discover it until after I did mine. The eBay seller I stole the picture form claims a power benefit with these but it's probably snake oil.
BCZEE is right, LS1 intakes are cheap. LS6 and FAST intakes are $$$. I think I paid $90 for a complete (rails, injectors, steam lines and TB) from a 2000 F-Body to use on a project and my bare one was cheaper than that.
Old 09-26-2012, 01:10 AM
garys 68's Avatar
2002 will be 3 bolt TB, it will bolt to the LS1 intake.
The standard truck pump will fit a cable TB with a little massaging. An 07+ truck pump will too. If you have DBW, a 98-02 f body pump with spacers, or 2010+ camaro pump (no spacers needed) will be spaced correctly.
LS1 intakes are on craigslist all the time for under $50. Mine included fuel rail, gaskets, and bolts. Btw, the bolts are expensinve.
You can use the flex fuel injectors on the LS1 intake, no mods necessary. The LS1 fuel rails wont reach though. You'll need to use the truck or aftermarket rails with modded hold downs.
Old 09-26-2012, 07:34 AM
Razor's Avatar
Cowl Hood is cheaper.
I added the cost to change over everything to fit under my flat hood, then went to the swap meet and bought a used $75 cowl hood. Problem solved.
Eventually when my bank account has recovered, I will look into a car style intake or painting the hood to match.
Old 09-26-2012, 08:39 AM
Strokinit383's Avatar
Just pick up the LS1 intake, run your TB and injectors.
Old 09-26-2012, 08:49 AM
sokr915's Avatar
I have an LS1 intake just sitting in my garage. Shoot me a pm with an offer if interested.
Old 09-26-2012, 08:56 AM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
I'm currently doing the same thing, and I'm just swapping to a stock LS1 intake because it's the cheapest option and the power from an LS6 doesn't justify the cost in the application. I've thrown LS1 intakes away in the past as have many others, and I found one for free to make my swap from the truck intake. Don't forget to source fuel rails and likely an EGR blockoff plate.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 09-26-2012, 09:24 AM
BirdsOnly's Avatar
A water pump? With spacers? How does that work?
Old 09-26-2012, 10:00 AM
garys 68's Avatar
The truck crank pulley and accessories are spaced 3/4" out farther than the f bodys. The f body water pump with 3/4" spacers between the pump and block will put the pulley in alignment with the rest of the pulleys.
Options:
spacers with f body pump (about $100 on ebay)
L99/2010+ camaro pump pump
press the f body pulley farther off the shaft
swap the truck pulley on f body pump
or buy one already done
http://www.foxlinders.com/accessories/waterpump.html
Quick Reply: Dah, hood will not close with truck intake
