9:1 compession N/A 408?
Old 09-30-2012, 09:24 AM
subliminal's Avatar
Default 9:1 compession N/A 408?
first stage i was gonna complete the longblock with my forged lunti roating assembly and weisco pistons fully ported tfs 215s and port matched ls6 intake and use my old 240-246 620 lift cam
now the compression be between 9.0 and 9.5, i plat on later going a pt 88 and differnt cam and fuel system probably twin 340s but anyway, how doggy would a 9:1 be na I am gueesing low to mid 400's with that cam and the ported ls6 intake im using also later for the boosted setup, please helm me out thanks sorry for bad typing in a rush
Old 09-30-2012, 09:25 AM
subliminal's Avatar
oh im m6 with 4.10's also
Old 09-30-2012, 10:56 AM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
I feel like a 408 with 9.0:1 static is gonna feel pretty soft down low. Even with the smaller runner heads its just not going to have the low end kick most people would be expecting from a stroker motor like that. It won't undrivable or anything like that, it just won't feel as strong as many would expect. With your plans I understand why you are doing it though. Turbo stuff is expensive. I would definitely expect less then 430 at the tire with the parts on there.
Old 09-30-2012, 11:58 AM
sick02ss's Avatar
i have a 408 with 9:1 comp. with .590/.590 112lsa with ls6 heads/intake im putting down 504rwhp and 511rwtq
Old 09-30-2012, 07:55 PM
Wow those are higher numbers then I would have expected. How does it feel in the low end? Very impressive.
Old 09-30-2012, 08:42 PM
6D9 Matt's Avatar
Wow yeah those are strong numbers for that compression, from what I would have thought.
Old 10-02-2012, 10:28 AM
Ellesone's Avatar
You dont build for boost and then worry about it being soft without the boost, simple as that. You have a plan and stick to it. Its still 400+ cubic inches Cam it properly and it should be fine
Old 10-03-2012, 04:16 AM
subliminal's Avatar
thanks guys looks like im gonna be around 9.8 with my tfs 215s 64 cc chamber and -15 dish and 60 thou head gasket should break 450
Old 10-03-2012, 06:31 PM
hymey's Avatar
its more the turbo/cam/cubes and cylinder head that determines spool, if u have a big cam u want more comp. sometimes better off with a small cam, good cylinder heads, less comp.. and right size turbo and run more boost. just after tuning a lot of turbo cars over years ..i run even less then 9:1 for pump gas stuff with right cam and turbo they come on boost right away ..the turbo makes the power, not the compression. the engine will be safer with less comp and cop more boost. seen a lot of engines still running 7.5:1 and running 30 psi and have no issues with lifting heads , doing big ends and cracking blocks as it increases the tuning window a lot.
Quick Reply: 9:1 compession N/A 408?
