lq9 or lq4 in 1970 chevelle
Old 09-30-2012, 01:41 PM
lanechevelle's Avatar
Default lq9 or lq4 in 1970 chevelle
i want to put a 6.0l with 6 speed manual trans in my 1970 chevelle just for street and strip. run 10s hopefully. i want to run naturally aspiration to start with then go with a twin turbo set up. want to use a stock bottom end to start with. so i dont know if i should start with a lq4 due to the dish pistons for ez of handling a turbo or lq9 for the higher compression and more hp off the bat. i just want to start off with just doing just bolt ons like a cam, intake, throttlebody, and a good comp tune. on buget now to get started. $5,000 or so. any suggestions would be awsome. thanks
Posted from LS1Tech.com App for Android
Old 09-30-2012, 03:03 PM
conan's Avatar
Are you planning to boost the stock engine when the time comes or pull it for some forged internals ? Also are you set on a turbo or is a supercharger an option ?
Old 09-30-2012, 03:21 PM
Old School Heavy
speedtigger's Avatar
Two different applications would have two different strategies. LQ9 for N/A and LQ4 for turbo would be optimal. You can get away with either in either scenario, but that is what would be optimal.
10s N/A in a heavy Chevelle would need all the advantage you can get. So for that scenario, I would say LQ9 with 243/799 heads, big cam, tall gears in a killer tough rear end.
Turbo will be a different animal.
Old 09-30-2012, 04:10 PM
wat do u find those heads off of r those the l92 heads off of a 6.2? i think i will go with a lq9 with boltons and do turbo setup later when i can do fordged insides
Old 09-30-2012, 04:22 PM
Old School Heavy
The 243/799 heads are typically found on LS6 and LS2 motors. You can go L92, but for what you are wanting to do, you will have to fly cut the pistons. Also, the L92 heads use different rockers and intake manifold which may add to your expense. However the L92s will make a lot more power.
Old 09-30-2012, 06:14 PM
jsmith564's Avatar
i have a lq9 6.0 with l92 heads, a midsize cam, has an ls3 intake and it screams. should meet your $5000 goal if we are talking just engine.
Old 09-30-2012, 07:18 PM
i dont know what a fly cut is? or i have seen lq4 with l85 heads would that work on lq9. or the ls6 motor heads are found in what car? sorry i am buying most parts off of car-part.com
Old 09-30-2012, 07:43 PM
jsmith that sounds what i am looking for i want it to scream. but how do u do a fly cut to make the heads work? wat cam did u use? or do u have a thread or list of ur build sorry i am so new at this ls stuff i am old school carb motor guy trying to convert lol
Old 10-01-2012, 11:55 AM
so for this build wat kind of cam and wat kind of hp would this set up be maybe
Old 10-01-2012, 12:00 PM
Old School Heavy
You can put really good sized cam in an LS motor with cathedral port heads without fly cutting if the heads aren't milled. This is not the case with the square port heads. For a cathedral port motor you can go with Texas Speed's Magic Sticks or some say even their T-Rex cam without fly cutting. That with a 4500 or so converter should get your heavy Chevelle in the 10s N/A if you have it all tuned and set up properly. But, from the sounds of your other posts in this thread, I would say you have a lot of reading and research to do first. I did months of reading up on this forum before I started to formulate my build.
Old 10-21-2013, 04:10 PM
How do you guys feel about a 6.2l instead of lq9 cost a lot more for upgradss . I have a friend with one that he will sell to me for 2000 with six speed tranny which is a 4l80e I believe both out of 06 esclade
Old 10-21-2013, 04:16 PM
What size cam r u running and injectors with the ls3 intake
Quick Reply: lq9 or lq4 in 1970 chevelle
