DBW gas pedal question, need some help
swapping a 2003 5.3L out of a suburban into a 69 FJ40. I have the gas pedal assembly from the donor vehicle and the TAC module. The donor vehicle came with adjustable pedals and this assembly is too big to use anywhere. I need a more compact setup.
What other years or vehicles can I look for that will compatible with my TAC module?
Thanks!
Thanks!
same vehicle but non adjustable pedel setup or just ask for pickup truck .
thay prob gave you one from a fancy suv thing. happen to me i called back and asked what could thay do . thay sent me a reg unit no charge and didnt want the old one back .
and check the threads i just bumped my modifyed dbw pedel thread up . hope it can help you .
That's my plan as well but the adjustable pedals have another arm and are longer over all that the other pedals. This thing is huge and there isn't a whole lot of real estate to begin with. I'm going to head down to a dealer and see if they have any on hand that I can compare with.
I used the DBW pedal from an 05 Tahoe in my foxbody it stuck way out so we cut about a few inches and welded to pedal back at the desired angle....ended up killing the sensor on the pedal afterwards but replaced it and have a working set up now.
Kind of a bitch to preload with DBW on street tires IMO
You probably have that big stupid plastic pedal. My '06 l33 came with that and wouldn't fit in my 80 series cruiser. I ended up getting a non adjustable pedal from psi and it along with the pedal to TAC harness from psi was plug and play. I shortened the n/a pedal and it fits great.
