help me decide LQ9 408 vs LS2 403 for s91 or s88 Build???
Ok here was the orginal plan which i already have the iron block and crank and bearings rods ect. i was gonna go 408 lq -15 cc dish pistons and my trickflow 215s ls6 intake and tb. but my buddy has a ls2 block for sale which there is a big weight difference there I was wondering if the weight difference would be worth using or stick with my iron block i already have, its going in my 98 camaro with alot of weight reduction tubular k member fiber glass hood no AC ect. but I was wanting to put a decent size stereo with a 10" sub. please give some advise sorry for the bad grammar I am in a rush at the moment
haha so does that mean I should go with the ls2?
also I have heard from some knowledgeable people that the iron block put put down more HP on the same amount of boost do to the way it retains the heat better or something similar to that LOL,
Just get the ls2 and build it and save it. Just swap the motors out like underwear lol jk the ls2 will save you some weight. Every engine is different throwing down power. Not sure how the heat tranfers from iron or aluminum. Aluminum is soft tho. But i see people here run boost on their setups with no problems it seems. Hopefully an expert can chime in and help. I just want the ls2 lol
The LS2 build is gonna cost me about a $1,000-1,500 but then I will be able to have enough parts all together to build a 408 shortblock to pretty cheap
lq9 is stronger. the weight difference is about 70-80lbs. just take out your a/c and compressor hvac and boom youve made up for it. just focus on taking weight out elsewhere. in the event that detonation or something occurs the iron will have a better chance of surviving. prefferably go with a sleeved block from erl.
see this is where I get confused one tells me iron other tells ls2 haha. but say with the same heads intake everything, on 12 pounds will the 408 put down better numbers than the ls2 403
thanks for your opinion bro, oh I forgot to mention what this car is being built for... my two main goals are to run a high 9 low 10 at 150 and be able to do 200 in a standing mile its staying m6 its going to be more less a pro touring/auto cross car thats why im concerned about adding weight upfront my goal weight is under 3300 thats with a decent sterio with a amp and small sub. no back seats spare bumper supports two race seats no ac tubular k member and control arms upper and lower fiberglass hood what do you guys think now?
what do you mean by that exactly like the block will be more savable or help prevnt a piston or rod exiting the side of it or be better if it over heats or something of that nature
