1000hp+ Turbo engine
Old 10-07-2012, 11:45 AM
TTR Jompa's Avatar
Default 1000hp+ Turbo engine
Howdy
which stroker kit would you recommend to a 6.0L iron block
Makes stroke bore?
Someone would have 1000 + engines here!?
all tips are welcome
thanks in advance
Old 10-07-2012, 11:56 AM
87silverbullet's Avatar
Originally Posted by TTR Jompa
Howdy
Makes stroke bore?
thanks in advance
Oh brother, here we go.
You may want to talk to camaroandreas on here since he is in sweden, I think.
Old 10-07-2012, 12:09 PM
TTR Jompa's Avatar
Yes he are from Sweden and I know him a little ! drive the monte carlo now!?
But I want to know if someone of you guys know what stroker kit you can rekomend me !?
I want to know if someone use some good stroker kit for low bucks?
Old 10-08-2012, 01:00 PM
Strokinit383's Avatar
1000+ hp and low bucks dont necessarily go together. Check out a few of the sponsors...TSP, TR, etc.
Old 10-08-2012, 01:34 PM
TTR Jompa's Avatar
Low buck or low buck....
If I say best stroker kit for the price then?
of course 1000+ arent cheap, but if some say that you dont need to buy that crank for 2000 and rods for 1500 etc
I think you understand where Im going
I gonna check those sponsors
Old 10-08-2012, 06:04 PM
gnx7's Avatar
there are plenty of people making 1000rwhp on stock crankshafts and forged rods/pistons. With high boost will they flex yes.... have there been many failures to date....? No.
How much power do you want to make? At around the 1000rwhp level the 4 bolt style heads are going to be the limit of keeping the head gaskets sealed consistently.
Old 10-08-2012, 10:48 PM
TTR Jompa's Avatar
Thanx for your awnser
My plan was to use my PT88 and maybe 408 /427 stoker
Would rather run with a forge crank than my casted one, just in case..
So a mls gasket can not handle 1000 + even with arp head studs !?
most people here in Sweden running tuned cars running E85
Old 10-08-2012, 11:15 PM
jridenour31's Avatar
The gaskets aren't the problem. The problem is the thin decks on the heads distorting when cylinder pressure is high. As far as turbo choice goes, I wouldn't run a t4 on a 400+ ci motor.
Old 10-08-2012, 11:47 PM
TTR Jompa's Avatar
Its a T4 housing on my turbo
Are the afr 225cc heads as bad !?
Old 10-10-2012, 09:08 AM
Thumpn's Avatar
I am running a 5.3 out of a 04 Tahoe, stock crank, forged h beam rods, forged pistons, stock heads with heavier valve springs and ported and polished, 7.9:1 comp, 110 oct. 950 cfm blow thru carb and twin Hx35 turbos pushing 28 lbs of boost and turning just over a 1000hp at 1028hp@ 6500 rpm, total build cost about $3500
Old 10-10-2012, 02:37 PM
TTR Jompa's Avatar
Me like
Old 10-10-2012, 03:27 PM
milkplus's Avatar
I wouldn't bother with a chinese crank. I'd spend the extra money for a Callies Dragonslayer if you absolutely have to use a forged crank.
Quick Reply: 1000hp+ Turbo engine
