When to change valve springs?
Old 10-08-2012, 07:11 PM
sabre_805's Avatar
Default When to change valve springs?
AFR 205 heads with doubles.
My cam is a split custom grind (sorry no specs).
Bottom end is stock dyno is 440 RWHP.
I have not been real hard on it.
When should I change out the springs?
I was told at 20k.
Any recommendations would be helpful.
Thanks.
Old 10-08-2012, 08:01 PM
blueshifty's Avatar
With that tiny amount of details, the easiest thing to tell you is to pull a few and check the install height. Brand of valve springs, ramp rate, lift, rocker ratio, etc all will effect the spring longevity.
Old 10-08-2012, 08:22 PM
Tainted's Avatar
Test and check only way to know. In general though, springs last about 25-30k without a donkey dick cam and stupid lift.
Old 10-09-2012, 12:20 AM
transwiz's Avatar
This guy is a friend of mine.He has a custom grind cam app:232/236 585 ish on the lift
lsa is 111,AFR 205 heads(dual springs),Harland sharp roller rockers,hardned pushrods,kooks
long tubes,custom tune,440rwhp.I hope this info helps.
Old 10-09-2012, 04:30 AM
vettenuts's Avatar
Do you have the 8017 or the 8019 AFR valve springs?
Old 10-09-2012, 05:09 PM
sabre_805's Avatar
Not sure on this.
I know I have double springs.
Just looking for a general idea of when to change them out.
We don't need to over complicate it.
Old 10-10-2012, 08:52 AM
TurboBuick6's Avatar
Pull some out get them load checked at closed and open height of the specs for the spring. If loads are low, change them out.
Old 10-10-2012, 08:55 AM
Sales@Tick's Avatar
It will depend on valve-train weight, how aggressive the lobes your camshaft is ground on, and of course how many miles they have on them.
How much duration and lift the cam has really has less to do with it than the above mentioned details.
Quick Reply: When to change valve springs?
