need help my wheel lock broke
i have a 98 ws6...i had tt2 rims on it and today i was putting the factory ones back on and got the back ones on...went to do the fronts and the wheel lock broke...same thing on both sides..one cracked but i got it off...but the passenger side locking lug broke and a quarter of it is broken off...how can i remove it? can a tire shop remove it? any help is appreciated need to get it off asap..only car i can drive right now
they seem cheap and the walls on them are pretty weak...i seen some ppl said to beat a socket over it but not sure if thats possible on these style locks..other option is to break the stud or cut it off from the back side of hub..just dont wanna damage the wheel in the process of removing.
I paid a tire shop to remove 1 before and all they did was the same thing I said to do except they charged me $20,I would try to get it off with a socket first,you really have nothing to lose other than maybe breaking a socket
Tool manufacturers do make socket kits for removing stripped/broken lug nuts and what not, I know Snap-On for certain. Air Hammer or hammer/chisel may work. The thin wall that is left I dont think will last very long when banging on it in the direction to loosen the nut. But, after that breaks off, the chisel should dig into the "meatier" part of the nut and remove it. I have seen the socket method done as well. If you can heat up the socket to make it expand a bit, hammer it on and then let it cool onto the nut for about 5-10 minutes (depending on how hot you get it), that should give you a better chance of the socket not slipping off. http://buy1.snapon.com/catalog/item....re&dir=catalog
You may be able to find a similar tool at Sears or a Harbor Freight center instead of chasing down a tool guy.
Go to the tire shop & theyll will use a torch believe me wont harm or damage the wheels, I had the same problem on my formula with chrome zr1s, tire shop was rushing to mount my rear wheels on & one of the jackass who worked there broke my lock in half. Half the lock was stuck in the lugnut hole, they used the torch to brake the stud, They bought me a new set of lugnuts w/key locks at autozone & replaced the broken stud. I was pretty pissed what they did, & glad they didnt damage my rim. Mines was exactly like yours in the photo.
