01-02 LS6 MAF Sensor Pinout?
Old 04-09-2004, 05:50 PM
PGA2B's Avatar
Default 01-02 LS6 MAF Sensor Pinout?
Noobie here
Anyone have a schematic or know the pinout for the LS6 5 wire MAF plug. I know the three in the middle are the MAF and the 2 outer wires are the IAT, but anyone know what wires are what?
Old 04-09-2004, 06:32 PM
Moderator
jimmyblue's Avatar
https://ls1tech.com/forums/editpost....post&p=1141944
Old 04-09-2004, 06:56 PM
slow's Avatar
https://ls1tech.com/forums/generation-iii-external-engine/147741-5-pin-maf-into-f-body-connector-wiring.html#post1141944
<right click, save as>
might work a little better, unless your either the owner, or moderator, you won't have access to edit posts
Ryan.
Old 04-09-2004, 07:39 PM
FDLS6's Avatar
Great info jimmyblue. Do you know where to get that 5 pin connector? I see pace has the $38 adaptor wire with all 3 connectors, but I'd like to hardwire mine. Don't need all 3 connectors, since I'd just cut it up.
Old 04-09-2004, 07:54 PM
slow's Avatar
you can buy the pigtail from GM or Delco it won't be cheap though
if you know the packard part number, PM it to me, and i can try to get you one through them.
Ryan
Old 04-09-2004, 08:39 PM
Moderator
jimmyblue's Avatar
Casper's Electronics makes one that integrates the
F-body IAT and MAF harnesses to the 85mm MAF.
I have bought from them and they're on the ball.
Pace resells this one at a markup. About $30 from
Casper's. If you knew this was a mod to keep, I'd
cut and solder and eliminate a couple of feet times
five wires from the engine compartment wireball.
Old 04-10-2004, 08:02 AM
PGA2B's Avatar
The GM part number is #15306113 that is the 5 wire plug but GM list is $34.00
P.S. THANKS JIMMY
Quick Reply: 01-02 LS6 MAF Sensor Pinout?
