OIL LEAK 'the bane of my existence'
Okay I installed a new clutch, flywheel, pilot bearing, slave cylinder and throw out bearing a couple months back and while I was down there I decided to replace the rear main seal as well. I also replaced the rear cover gasket with a seemingly good looking 'used' gasket. My buddy has a car lift and is a very knowledge mechanic and LS enthusiast. He has built motors and is currently swapping his car from a manual to an automatic just to give you an idea of his level of skill. He did pretty much all of the hard work on my car but I was there to help with simple stuff. Prior to the clutch install I had no oil leaking, but now it is leaking from the weep hole in-between the transmission and engine. I followed the dripping oil up the drivers side of the block up to the back of the engine. I replaced the drivers side valve cover (didn't fix it). I pulled of the intake and noticed the opsu and cps area was oily and dirty plus the opsu was finger loose. So I snugged the opsu up cleaned up the area and its still leaking. It 'appears' to be leaking out of the weep hole still and makes about a cd size oil spot whenever its parked. I really don't want to pull the trans again unless im positive its coming from there.
Any suggestions?
Any suggestions?
sorry if this comes off a lil harsh but why in the name of god would you replace a used gasket with another used gasket? Especially when theres so much effort involved in getting to it again?
The dye is going in tonight. If I determine that the oil is coming from inside the bell housing, is it necessary to use the alignment too when re installing the rear cover and gasket? Should I add rtv to the bottom off the rear housing? What are the proper steps to take?
I had a similar problem with my car. It was leaking from the center of the crankshaft. There's a cap on the end that's exposed to the crankcase and it can get loose and leak oil into the bellhousing. So two options: pull the oil pan and fix the leak, or try some JB Weld in the crank hole. I usd option 2 and no more leak. Also, keep in mind with that much oil leaking, your clutch disc is shot. Ask me how I know!!!
I'm pretty sure I didn't touch it. If the galley plug is leaking, is there a way I can tell by removing the starter and feeling around inside? I assume the teeth on the flywheel would be all oily and and the back side would be dry. Meaning it is leaking onto the flywheel face and getting slung outward. If it is just the rear main or rear cover leaking, then the flywheel should be seemingly dry? Is that correct? The reason why I ask is because the clutch doesn't feel like its slipping.
Try putting the car on a lift, remove the small dust (black plastic) cover between the engine & trans, on the driver's side. Then rent an optic scope/camera & look into the bellhousing/rear cover area. Your friend just may have a scope. If not, perhaps your local parts store has one. The 'rental' allows you your money to be refunded when you return the scope.
I've had this same issue happen to me just this week. I did a A4 to T56 swap about 500 miles ago. Prior to that I had zero issues with oil leaks. Just this past Friday I noticed a leak in the same area that you are talking about.
Well, I took the intake back off, because the opsu looked wet with oil when I check it with a bore-a-scope. I replaced the original valley cover gasket, knock sensor oil seals, knock sensors (cus they looked rusted), knock sensor harness, opsu (added extra thread sealer), and cam position sensor o-ring. Torqued everything to spec. Now I'm gonna drive it and see if it continues to leak. If it does I'm gonna pull the starter and see if I can get a better look at the rear cover through the bore-a-scope.
Still leaking.....but I check out the inside of the bell-housing with a bore-a-scope again and I clearly see that it running out from behind the flywheel. The flywheel appears to be dry front and back so I believe it is leaking from the bottom of the rear cover.
I have a new issue. I ended up replacing the valley cover gasket, opsu, and cam position sensor o-ring. Since I had the valley cover off I also replaced the knock sensors, knock sensor oil seal and knock sensor harness. I bought brand new BWD knock sensors and a new Dorman knock sensor harness from Oreilly Auto Parts. Put everything back together and when I started it up my SEL started flashing, but the car was running fine. I turned it off and restarted the car back up and the flashing SEL went away. After driving the car a week now It has only happened one other time and turning the car off and back on made it go away. I had it scanned for codes at Oreilly, but they said they didn't see anything and wouldn't be able to unless the SEL remained on.
Not sure what to think.
That sounds exactly like my situation. I pulled my tranny and clutch out this past weekend. What I found is identical to what you've found. The clutch assembly and flywheel surfaces was dry, no oil. I found no oil around my OPS or CPS. Pan gasket looked fine.
I changed my rear seal and rear cover seal and everything seems ok now. I'm afraid to look under my car though
