Difference between ls2 and lq9
Old 10-14-2012, 05:31 PM
Bouyahbb's Avatar
Default Difference between ls2 and lq9
Looking for lq9 for twin turbo set up friend of mine said go lq9 cast iron block handle the boost better, is te lq9 just like a ls2 as in engine mounts, water pump ect ect??
Old 10-14-2012, 05:36 PM
babbage1109's Avatar
All gen 4 blocks are setup the same.
Old 10-14-2012, 05:39 PM
litle88's Avatar
Go iron Lq9 both have 4.0 bores and yes you can interchange accessories.
Old 10-14-2012, 05:40 PM
Sales1@Texas-speed's Avatar
Yes either block will bolt right in place of the other.
Old 10-14-2012, 06:00 PM
Bouyahbb's Avatar
Thanks very much guys, where can I learn more about them??
Old 10-14-2012, 06:01 PM
Bouyahbb's Avatar
And good place to buy one??
Old 10-14-2012, 07:48 PM
Bama99z's Avatar
I know that it is hard too but just be patient. I have been looking for like 6 months. But yesterday I picked up a LQ9 80,000 + complete shortblock for $ 400.00.
Old 10-14-2012, 10:16 PM
Bouyahbb's Avatar
Bama eBay??
Old 10-14-2012, 11:14 PM
wilfredes's Avatar
Old 10-15-2012, 12:15 AM
98z8uup's Avatar
Where did you find it?
Old 10-15-2012, 09:06 PM
Bama99z's Avatar
I found it at a local shop that is into LS1 swaps into 80's big body car's.
Old 10-15-2012, 09:38 PM
formerly twolow02fransen (2014-1-2)
02_Orange_D1SC's Avatar
only differences between the two are
LS2
58 tooth reluctor wheel
aluminum block
243 heads compression 10.9.1
knock sensors are located on side of motor
LQ9
24 tooth reluctor wheel
iron block
knock sensors located on top of motor in valley cover
317 heads compression 10.1
crank rods pistons are the same on both motors
Old 10-15-2012, 11:20 PM
pairof69s's Avatar
you would need to drill the block for the lower alt bolt hole
Old 10-16-2012, 08:53 AM
omc8's Avatar
LS2
aluminum block
LQ9
iron block
IIRC the early 2005 LS2 were 24x then changed to 58x. Most will be 58x
Old 10-16-2012, 02:35 PM
dodson55's Avatar
2006 ls2 in a gto had 24x also
Old 10-16-2012, 08:21 PM
Bama99z's Avatar
Pairof69's, I am actually using the LQ9 as a replacement in an F-Body that currently has a 5.7 in it. If I understood you correctly you said that I would have to drill the lower ALT bolt hole,is that correct? Or is that hole in the correct location on the LQ9?
Old 10-17-2012, 05:35 PM
omc8's Avatar
Yes you have to drill one . that will give 2 mounting points . You cant do anything with the one at 10' o'clock position.
Quick Reply: Difference between ls2 and lq9
