F13 vs. El Torro
PREDATOR-Z "El Torro" - 230/230 .612"/.592" 111+2 LSA
Based on what I am wanting, I have narrowed it down to these two cams. I've seen both of these cams compared to a multitude of different cams, but never to each other. Which one would you go with and why?
When this cam goes in, I will have a FAST 102/102, Delphi 85mm MAF, FTP 98mm lid, TSP 1-7/8" LT's and TSP true duals. I'll be running stock gears for the meantime, but plan on getting 4.10's before long. Stock heads will be used (I know, severely limits the setup).
Comp sucks. Futral doesn't use Comp. Seen some wicked fast mild and heads cam cars though with the El Toro.
What are you using the car for and what are your goals?
It is not my daily driver, it's my weekend warrior that will see track days, but mostly driven on the street. I want to have a good torque curve with around 400+ HP without needing to rev to 7,000 RPM or going too crazy with the amount of lift.
ALSO! My above dyno dyno was with 20* total, I think 21.5* pinged everytime on the street. Cali 91 pump....
OP- do a search, there's been a lot of success with the Toro and F13 cams..honestly, can't go wrong with either. The Toro will have a little rougher idle IMO, but both would produce similar #'s
