LS swap into 97 suburban
Old 10-15-2012, 05:27 PM
slicpartna's Avatar
Default LS swap into 97 suburban
whatz up ladies and gentlemen
im fairly new to this site but i have been reading alot of information and taking notes.
im very excited about doing the swap but sourcing parts is a beast and expensive!!
i'm currently working on swapping in a 5.3 with a ls6 intake into my 97 suburban.
i have a ls6 intake on the way but i need a fuel rail.
would i need a fuel rail from 97-98 corvette or would a 98-04 f body work?
if the latter, how would i hook up the return line?
thanks
Old 10-15-2012, 08:26 PM
greenvortec97's Avatar
Use a corvette z06 fuel filter on the fuel rail with an f body fuel rail.. The stock vortec pump is good for 400hp as well. Good luck with your swap man if you need help with what parts to use just pm me. I've done the swap to obs trucks a million times
i forgot to add that the way this works and also the reason of why i say to use the vette filter is because the filter will act as a splitter. It's regulated on the inside. on one side of the filter it has one fitting that will slip onto the fuel rail. on the backside of the filter there is a high pressure fitting and a low pressure fitting. otherwise known as your "feed and return". so NO. you do NOT need an early ls1 vette rail. just disconnect the fittings at the firewall behind the block and tie into those.
Old 10-15-2012, 10:58 PM
wildcamaro's Avatar
I wouldn't think placing the filter/reg right on the fuel rail would be good for fuel pressure especially with an obstruction right before they rail...I've just never seen it done that way...
Old 10-16-2012, 08:03 AM
Trust me, its been done time and time again. Check out ls1truck.com's swap section. Motors run just fine.
Quick Reply: LS swap into 97 suburban
