243 heads that were milled to 53cc
Restricted User
looking at picking up a engine.. and the guy said the heads are milled to 53cc chambers.
so how much was it milled, about?
what does that do to my valve geometry?
what length pushrods do i need?
rockers?
ps, motor is complete minus pushrods and rockers... thats where this guys build came to a stop.
rockers?
Restricted User
edit: heres all the details i have at this time
383 short block K1 rotating assembly.
K1 crank 4.000 4340 crank.
K1 6.125 Forged H beams
Wiseco -32cc forged pistons.
Comp cam hydro roller lifters
With 64cc head motor would be 9.4-9.5 or so on comp ratio
LS6 243 Ported heads
New valve job.
Titanium retainers
Milled to a 53cc
2.055/1.6 stainless valves.
Manley valve springs good to .650
631/631 240/244 lobe center 111
New valve job.
Titanium retainers
Milled to a 53cc
that is an absolutely terrible setup, sorry but its not gonna make near the power it should. Why the huge dished piston then small chamber heads?? compression with those heads on it will be 9.4 unless you have a typo with the piston dish.
valves are gonna be shrouded to death
and that cam is entirely too big for that setup
Restricted User
i believe it was suppose to be a boost motor, although i didnt want to run boost. i was just gonna toss it in a car and drive it the way it is.
but, that being said.. what changes should i make to make it the way it should be? set of pistons? different set of heads?
well it will work to drive NA, I would definately go with a smaller cam though 23x/24x .600, otherwise its not gonna make anything down low. just dont expect to make huge power with it. Not to mention anything over .600 lift there is no way you will have enough piston to valve clearance
