Sponsored by: DashLynx
!wire mod (no cut) question
Old 04-10-2004, 01:33 PM
LawmanSS's Avatar
Question !wire mod (no cut) question
After searching and reading threads about the passenger !wire mod, I have a few questions. I was planning to buy the Weatherpack and/or Metri-Pack terminal tools to disassemble the connectors. One was a hollow tube-looking device with a screwdriver handle and the other looked like a thin, long blade, also with a screwdriver handle. Are these the only tools I need to disassemble/reassemble the connectors? If I go this route, do I still need to extend the wiring harnesses or is there already enough wire? Any suggestions, tips, part numbers, advice, etc. would be appreciated!
Old 04-10-2004, 07:34 PM
felton316's Avatar
No, you will not have to extend the wiring harness. I did the no cut method, but I just elongated the hole enough to fit the connector through.
Old 04-10-2004, 07:36 PM
BrostalSS's Avatar
I did it without cutting a single wire
Scalpel's Avatar
Where are you getting the tools to remove the pins?
Old 04-10-2004, 07:46 PM
BrostalSS's Avatar
I didn't , just made an oblong hole. It turned out quite nice.
Old 04-10-2004, 07:48 PM
Scalpel's Avatar
I was referring to Lawman's first post since he's gonna buy the tools.
Old 04-10-2004, 11:33 PM
LawmanSS's Avatar
I found them on a site called waytek wire:
http://www.waytekwire.com/index.htm
The tools were cheap...one was $5 and the other $7...just look under tools, packard...
Old 04-10-2004, 11:34 PM
LawmanSS's Avatar
Thanks for the replies...I am glad that I don't have to extend the wires...I'm also hoping that I only need these two inexpensive tools!
