Spark plug wire length for coil packs
Does anyone know the required length spark plug wires for a LT1 with coil packs using Canton valve covers? I am currently out of town for some time and I cannot take measurements at this time. If someone knows a PN that would be great too, looking for MSD. I noticed the truck ls1 wires are a few inches longer than the ls1 wires, would this work? thanks guys.
That's MISTER MODERATOR
As this is custom work, nobody knows where your coil packs will end up except the guy fabricating their mounting. Once that's done, you'll need to take a measurement.
As most SBC plug ends are 90 degrees, you'll need to get either custom wires or make them up yourself.
Just say NO to the Taylor wires, many posts about them arcing and/or falling apart.
I got the MSD cut to length wires for a LS1 last night. The kit come with the 90 degree boots installed and you cut the length and add the coil connections so I guess I'll use the 90 degree boots like someone mentioned above.
I've also had problems with the taylor wires, wont do those again...
