Walbro 255 max with h/c/i and N2O?
Old 10-19-2012, 01:17 PM
SprayedLT1's Avatar
Default Walbro 255 max with h/c/i and N2O?
I'm wondering if anybody knows how much hp a single Walbro 255 can handle with nitrous? My current set up is stock bottom end 355 (forged pistons), LE3 heads/LE ported intake, COMP XFI 280 cam, SVO 30# injectors, in-tank 255lph, Nitrous Works wet shot/plate jetted @ 175, yadda yadda yadda. Made 365rwhp on motor through a Yank SS3600/FLT Stage 4/Moser 9", we didn't get to dyno it on spray (I know...dyno numbers don't mean much, just wanted to show it's not making huge power n/a). I have a couple grudge races coming up and I'd like to toss a fogger on for a 2nd stage to add a little more "just in case" as long as my fuel system can handle it. Opinions?
Old 10-19-2012, 01:29 PM
Dave357LT1's Avatar
Play it safe and run a seperate fuel system for spray or run twin 255'.
Old 10-19-2012, 01:48 PM
nitrous2fast's Avatar
Depends on your fuel pressure really. Most pumps can move more volume at a lower pressure.
Old 10-19-2012, 01:52 PM
SprayedLT1's Avatar
I probably will over the winter, but until then if I can safely get by with a single in tank for just this weekend I'd like to add more powa
Mine's at 45 psi
Old 10-19-2012, 03:02 PM
why not put 200 jets in the plate?
Old 10-19-2012, 03:15 PM
SprayedLT1's Avatar
I thought about that too, but I'd like a separate stage for "just in case I need a little more". Grudge racing isn't all about going as fast as you can, it's about going just a little faster than the other guy
I'm also planning on doing some back to back tests of plate vs fogger next year, and may be switching if the fogger works better, and possibly doing two stages both foggers
Old 10-19-2012, 04:31 PM
TwoFast4Lv's Avatar
My racetronix Made 680 RWHP on my car no issues at all
Old 10-19-2012, 05:10 PM
SprayedLT1's Avatar
I won't be making nearly that much, even on both kits
Old 10-19-2012, 07:41 PM
bowtienut's Avatar
527 SAE rwhp here on the 100 shot with a Walbro 255 and my own wiring.
Old 10-22-2012, 06:11 PM
Big Al's Avatar
I ran two 255's on my 95 Z with a 150 shot. Mainly because if the pump dies when the spray is on, boom.
Al 95 Z28
Old 10-22-2012, 09:22 PM
Rob94hawk's Avatar
Dave at Nitrous Outlet told me that the Walbro 255 and the harness is more than enough.
Old 10-22-2012, 10:17 PM
SprayedLT1's Avatar
Wow you're making some power n/a. Im guessing I'd be about there with another 75 on top of my 175. I'd like to only do another 50, doesn't sound like it would be too risky.
Thanks guys
Quick Reply: Walbro 255 max with h/c/i and N2O?
