Team Z Fox K member
Old 10-19-2012, 10:42 PM
ronnieforrester's Avatar
Default Team Z Fox K member
Anyone using one ?
Got mine in today and the truck oil pan hits like crazy and not close to lining up.
its actually rubbing where the sump arches back in to the shallow part of the pan, I know the sump of the truck pan may hang too low but im just mocking it up for now.
from the looks of the pics it looks like the sump of the car oil pan is not as deep in the sump area but still looks like it will hit where the sump "arches" back in to the shallow part of the pan.
any thoughts?
ill call team Z monday but trying to figure something out this weekend.
Old 12-27-2012, 08:19 PM
TxFireman1972's Avatar
What did you end up doing on this?
Old 12-27-2012, 09:00 PM
willys_truck's Avatar
Here is my 93 coupe team z k member, truck pan. You probably have the motor mounts flipped wrong. The truck pan will work with the team z k member but the stock f body pan does hit the k member and will not work with the team z k member.
Attached Thumbnails Team Z Fox K member-pan.jpg   Team Z Fox K member-mustang.jpg
Old 12-27-2012, 09:02 PM
Sleeperls's Avatar
what about the hotrod/hummer pan?
I was planning on ordering the whole k member kit/struts/castercamberplates here in a few.
Old 12-27-2012, 09:13 PM
Do you have any better pictures?
Old 12-27-2012, 10:06 PM
If I get in from work tommorrow before dark I will get a pic of the pan clearance with the car sitting on the ground.
Old 12-28-2012, 12:48 AM
soundengineer's Avatar
agree'd
Stock Fbody Pan does not work with the Team Z K-member
however... a little modification, and it works just fine..
Old 01-08-2013, 12:28 PM
jfisher's Avatar
I'm running a Team Z. Truck pan fits fine, just don't have enough ground clearance. My car is pretty low though and will only get lower. Thread here:
https://ls1tech.com/forums/conversio...l#post17010271
Quick Reply: Team Z Fox K member
