Big boost with rectangular port heads? Step inside
So i closed my season on a lean #7 cylinder, which made me tear into my engine sooner then expected. On inspection of my heads i noticed little cracks on the head between the valves. Im positive they werent there before installation. Im also switching around intake setup and have the chance to go to a rectangular port head. Ive searched for about a week now seeing no one really put a rectangular port head to the test of high boost. Many that see 10-12 psi, but im looking at 24-28 range. So who has put a LS3, LSA, LS9 head to the test? Would notice a power gain in the lower at lower boost levels with these heads? Or should i stick with my 317s?
Background on the car: 370, GT55-94, 25 psi average, E85, 1/2" ARP studs, LS9 gaskets . Current heads are hand hogged 317s that held up to over 75 20-28 psi passes, and probably hundreds of street pulls.
The LSA and LS9 head would be much better than the 317s. Since you are setup for it, Id rock the LS9 because of the 1/2 head bolts. It will take a little machine work, but youll be happy with them.
We run 19-22 psi on the ZR1s with out issue and getting pretty crazy with the tuneup and water temps ( 25-27* timing and AFRs in the 13s on a road course)
Id stay FAR away from the 821 or 823 LS3 castings.
Location: Home town Clive,IA current town FORT BENNING GEORGIA
From the old beat to death L92 head threads seems like if you try and machine them to run 1/2" studs they break super easy under a decent amount of boost. I'm running standard diameter ARP studs and will see how far i can push my L92's with the GT-88
