Big boost with rectangular port heads? Step inside
Background on the car: 370, GT55-94, 25 psi average, E85, 1/2" ARP studs, LS9 gaskets . Current heads are hand hogged 317s that held up to over 75 20-28 psi passes, and probably hundreds of street pulls.
We run 19-22 psi on the ZR1s with out issue and getting pretty crazy with the tuneup and water temps ( 25-27* timing and AFRs in the 13s on a road course)
Id stay FAR away from the 821 or 823 LS3 castings.
The LSA and LS9 heads are also a much better material.
The 317 vs the LS3, I have not the slightest clue. I have one of those too, Ill cut apart.
