no fire
no fire
I have a 95 Z 28 lt1 6 speed I was driving and my RPM's started fluttering from 1 to 3 grand and backfiring the car with Idol but it ran really frost spec far I turn the car off and let it sit for a minute and then started my car back and it ran fine and got me home it did start a flutter again at about 50 miles an hour and then smoothed out early that morning I went out and started the car which is started fine I made it down the street and it died now the car has no fire will not start I did pull a coil and have it tested for continuity everything came out fine the same as a brand new coil any help in this matter would be greatly appreciated I'm feeling really lonely and depressed without my car please help ! thanks and I hope to hear something back soon
Village Troll
Possible fuel pump. Has it ever been changed? If so, was the fuel pump bucket reused? It's possible the pump is bad and was able to cool off enough to run for a few minutes before heating up and causing problems. Two things you can do is either/or buy a fuel pressure gauge and test the fuel pressure. The other is to get some starter fluid and see if it will fire by spraying some into the throttle body while the engine is being turned over.
You can reference the "how to" from www.shbox.com on how to locate the Schraeder valve and testing fuel pressure as well as slew of other how to's.
the car is getting gas I check the fuel pressure there is no fire to the plugs I've also pulled the coil and check the coil already and the the continuity is the exact same as a brand new 1 so I pulled a spark plug and hooked a spark plug tester to it there is no fire getting to the spark plug whatsoever the car will turn over fine and everytime I turn it over it does buildup fuel pressure I'm not sure what this could be any ideas or if you need me to try anything else to the car to troubleshoot I will be glad please help
Village Troll
Did you check fuel pressure with a gauge? If it's not a fuel pump then I don't think it's the opti since once that goes it doesn't come back. At first I was thinking it was a loose rotor, but then you say it ran fine after sitting for awhile so... Dunno.
no fire
Thanks guys haven't had a chance to work on her yet really bust at work I will soon and will check icm then opti I really appriciate the feed back as soon as she is running again I will update once again much appreciated this forum is awsome everyone has helped so much keep ur fingers crossed gotta get her goin and painted for up and coming power tour this coming year starts in grand prarie can't wait ! Tty soon
update
thank you for everyone's advice and I appreciate everybody's help a problem with my 95 Camaro Z 28 was the ignition control modual I really appreciate everyone's input on this and help a lot I'm so happy it was not something major now I am ready to put the new sunset orange paint on her !!!! I've already done the 2002 conversion on the front and and have the SS Wing she is sure going to be beautiful and her new orange dress once again thanks!
