Going for MOAR power, new motor and MOAR goodies! gen IV 5.3 & tc78
Popped the old iron block 5.3 on the dyno last go around, broke a ring land on piston #7. So naturally its time for an upgrade
Here was my old setup-
And here is the upgrades in the new setup
-gen IV aluminum 5.3, uses the newer LS3/LS2 components and should be a stronger motor, also dropping 100lbs on the front end couldnt hurt
-Cooling Mist boost activated deluxe kit with their super atomizing injector and solenoid upgrade
-Patrick G custom ground cam 22*/22* 60*/60* @ 115+ 4
-Deatsch Werks 96lb injectors
-Deatsch Werks Fuel Pump
-96mm Maf Housing
-LS3 Maf
Other Info-
-Ported/ Milled 317 heads should be around 9.7 CR
-Fast 92/92
-TC78 turbo, custom with a 3.5 " downpipe and a .96 a/r
-ls7 Lifters
Just got the motor dropped in, waiting for my new front cover to come in so i can finish assembling everything
Its been a learning process on figuring out what all i needed to make this Gen IV motor work. but i think i finally got it all figured out
-96mm Maf Housing
-LS3 Maf
Other Info-
-Fast 92/92
-ls7 Lifters
Meth tank mounted
solenoid mounted behind the headlight
Injector mounted
New 96 mm Maf Housing and LS3 maf
View from under the car of the wastegate
Car is all back on the road now, and undergoing some street tuning one my trips back and forth to work
Injector mounted
