Lots of LS1/LS6 Parts, some new, some used, (Clutch, flywheel, Oil pan, and more)
Category: Drivetrain
Price: $400
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO
Location (State): OH
Item Condition: Brand New
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Items are priced as marked
New/never used:
RAM Clutch 520 Clutch Slave Cylinder/throwout bearing - $100
JEGS:http://www.jegs.com/i/Ram+Clutches/798/520/10002/-1
Originally thought I would use it but I had to use the DeLorean slave cylinder instead. Never even removed the red cap.
Centerforce Duel Friction 11" clutch and pressure plate - $350
JEGS: http://www.jegs.com/i/Centerforce/183/DF017010/10002/-1
(pressure plate has a few nicks to the orange paint but thats it. It was bolted to the engine one time (without the clutch plate underneath) to check the fit, then removed. It's never been used or compressed. Comes with the pressure plate bolts.
Iron Nodular Flywheel for 11" or 12" Clutch- $70
JEGS: http://www.jegs.com/i/JEGS+Performan...01260/10002/-1
Like the other parts, thought I would use it, ended up having to make my own flywheel instead. Never used.
Listed here are the used items. These items were taken off the motor. I dont believe there is anything wrong with them, but I cannot make any guarantee so each is sold as is.
Single Camaro engine mount - $20
Camaro Exhaust Manifolds - $100 (for the pair)
Camaro Oil Pan (comes with pan, deflector plate, sump, and dipstick) - [SOLD]
Sorry it's not cleaner. I'll wipe it down before sending it out.
Valley cover with rubber grommets - $20
Fuel rail lines with evap solenoid - $20
Camaro Power Steering Pump -[SOLD]
Camaro EGR solenoid/piping - $35
Valley head coolant crossover pipe - $25
I pretty much only accept paypal or cash if you are able to come pick something up.
I am willing to ship. If you're interested in some stuff, let me know what and I'll try to assess the costs of all the items together.
Anything that doesn't sell will probably go to ebay.
Thanks for looking, PM with questions!
-Nick-
The disk and pressure plate together weigh a little over 30lbs.
So far the oil pan, coolant tubes, and power steering pump are sold.
I ended up listing several of the parts on ebay. For those interested, here are the links. They are all no reserve auctions starting at $.01.
Links:
RAM Clutch Slave Cylinder:
http://www.ebay.com/itm/290812729039...84.m1555.l2649
JEGS Performance Products LS1 Flywheel:
http://www.ebay.com/itm/290812738881...84.m1555.l2649
Centerforce Duel Friction Clutch Kit with Hardware:
http://www.ebay.com/itm/290812751605...84.m1555.l2649
I also have a new "621" Chevy Bellhousing P/N:3988621 listed:
http://www.ebay.com/itm/290812744658...84.m1555.l2649
Like I said, all auctions start at 1 cent with no reserve so whatever they go for is what they go for.
Links:
