Cam selection, 6.0/LS3 build
Looking for a little help in picking a camshaft for my build. The current plans are for a 6.0 with LS3 heads and intake. I'm looking a for a large, but streetable cam. Down the road, hopefully next winter, I'll be looking at doing a stroker build on it, but I'm just going to stick with the stock 6.0 block for now. What off-the-shelf cams would be good to look at for my build?
Thanks
Thanks
MASS seller approved
would help if you state more about your build such as ls2, lq4, lq9, ly6, etc (to have a better idea of compression working with and figure in possible head milling options), stall and gears you intend to use, vehicle type, etc....
My fault for not adding the extra info. it's an LQ4, I may go with a thinner head gasket to try and bring compression up a hair. It will be bolted up to a T56, and put in a Trans Am with 4.10 gears. My goal is a high performance street motor with the option of making it to a track if I feel like it. Assuming I get done by my goal date, it will see ~15000 miles next year.
[QUOTE=Tainted;16874159]An ls3 also has a way bigger bore for those heads though. Dont expect near those results or proper ptv clearance[/QUOT
well my old ly6 ran 6.18 on just 150 shot yes a ls3 runs harder but no reason a 6.0 lq4 ls3 head wont run
something like a 224 230 590 590 on 108 check ptv and roll
I got in touch with cam motions,gave them all my specs on my ride they ground a cam for my truck,pulls good from idle to 6,750.I ran a 7.88 in a 1/8 an get 20 plus mpg.
I'd like to stay away from machine work for now if possible. This cam would basically be just to get me by for the year until I do the bottom end build next winter. Anyone know anything about CompCams LSR or Thumpr cams and how they might stack up?
I do still have my stock LS1 heads and LS6 intake. I could use them if it's safer than doing the LS3 top end without the bore/stroke to the block.
You can still hope for good power using these ueads, but I cant stress to you enough the importance of picking the right cam.
Try eps for a cam, they do a lot of 6.0/ls3 combos.
Op im building my setup the same as you basically. I know you said you want to stay away from machine work, but you need to get the compression up. Im using an LS2 block and rotating assembly, pro comp CNC ls3 heads and ported ls3 intake. I dont want to give out my cam specs, but i had Ed Curtis custom grind me a cam. 23x/24x .63x/.63x on a 112+x. Its bigger than the other cams being specd here by a good margin. I told him i was decking the heads .030 and did NOT wxnt to fly cut and this is what he sent me. Take it for what its worth OP.
LS1Tech Premium Sponsor
You might checkout the new PRC 255 cc aftermarket casting LS3 heads. They move roughly 370cfm and have a smaller than stock runner size. Not to mention the relocated valves will help to keep head airflow high where the stock head likes to drop a lot of airflow in 4" bore applications.
http://www.texas-speed.com/p-4008-pr...der-heads.aspx
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
What's different about the pistons that should concern me with the piston to valve clearance? I can understand cutting it close with the valves and cylinder walls, are there different reliefs in the pistons?
