Fastest Stock Block/Crank 6.0 in Country Forsale
Category: Racing Parts
Price: $3300
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): MO
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9
LS Engine?: Fits LS Engine
-370 CID LS done by Mike Lough Engine Service in Oak Ridge MO
-Factory Gen III iron block w/oiling mods
-6.0 factory crank
-Diamond Custom 9.0 CR piston w/tool steel pin
-Total seal rings
-Callies H-Beam w/ARP 2000 bolts
-Clevite H series bearings
-Balanced rotating assembly, Crankshaft snout doweled for balancer location, Block bored .030", Torque plate honed, Decks surfaced, Oiling modifications, Main caps doweled w/ ARP Studs, Assembled
-Engine holds great oil pressure and compression test is good if wanted as is.
-Can add custom grind camshaft for your application for additional price
This is the fastest LS Stock block and crank 6.0 drag radial engine in the country, tuned by Burgess Performance in Missouri. Engine can be freshened up or bought as is. Mike Lough (573-243-8944) will be looking at short block before purchase and can detail any info needed. We can complete the build with any combination of top end and cam combos, as well as run the engine before it leaves.
3300.00 freshened with bearings.
3000.00 as is single season of passes.
I feel these prices refelect a very Firm and Fair price based on Machine work and parts involved.
Anything additional wanted above this will need to be done through Mike after payment on engine to myself. Contact me directly if you're interested in purchasing. Call Van Burgess 573-450-2538 Best means to Contact!!
Parts below are additional if wanted that i have on combo.
* L-19 Head studs 300.00 SOLD
* PP Balancer 150.00
* Comp Short Travel lifters Bar type 350.00 SOLD
* Link to Vids of engine in action.
http://www.youtube.com/user/fast383v8?feature=guide
